actioner problem
10.09.2023 01:57 # 1
musa46
Friends, the semi-automatic 207 I bought last Monday left me stranded on the road. Today I got in the car with the kids and I hadn't even gone 3 km yet. I heard a few squeaks and noises when I got close to the lights and it stopped like a manual transmission. I pressed the starter a couple of times and it started rubbing like a flat battery. I thought something would happen to me so I towed it to the repair shop. We couldn't get the car off the tow truck, the wheel wasn't turning (the screen showed a gearbox fault). We got it off somehow but the gear was stuck. According to the mechanic, the pressure pad on it hadn't been changed yet, the ball bearings and all were broken, and there was no brake pad left. Anyway, the pressure pad was changed but the car still wouldn't start. The AKSIYONER (clutch robot) was broken and locked. The car wouldn't go into neutral. Since it didn't go, the mechanic connected it to the computer and made the adjustment. He couldn't do it, he talked to a couple of brain specialists, and they said it was malfunctioning and would it be replaced? I wonder if the actioner can be repaired. I live in Kahramanmaras. By the way, the actioner that is said to be broken has been replaced before because it was new, but I guess it had the same problem before and since the pressure pad wasn't replaced, it broke again. The actioner is said to cost around 12 thousand, can it be repaired? Has anyone had this problem before?
