ACİLL !! PROBLEM OF 308 SHIFTS
08.05.2020 16:49 # 1
nupel307
Friends, I have the 2008 model 308. There is no sound and no problem at the start. After moving the car, let's say I had to see a pit and slow down. When I throw the gear into one and keep moving, it sounds like a very small plug. this voice continues..only no problem on departure. what could be the problem .. can it be caused by transmission or other reasons?
08.05.2020 16:49 # 2
[QUOTE = nupel307] Friends, I have 2008 model 308 .. No sound and trouble at start ... after moving the car let's say I had to see a hole and slow down ... when I throw the gear to one and keep moving, it sounds like a little plug ... This sound continues when it throws at 2-3 ... just no problem on departure. What could be the problem .. Can it be caused by transmission or other reasons? [/ QUOTE]
Where the sound comes from is another matter, when you slow down your vehicle 1. You should not force you to put it in gear because it is enforced and harmful. In this case, you must either stop completely and shift to 1st gear or continue with 2.
08.05.2020 16:49 # 3
nupel307
brothers have the same problem with other gears
08.05.2020 16:49 # 4
[QUOTE = nupel307] brother other gears have the same problem [/ QUOTE]
I did not comment on the problem anyway. I just said how it should be used properly.
You go to a master and have your motor ears checked. Let's see what the result will be.
08.05.2020 16:49 # 5
toga406
I think we should have neglect to control
08.05.2020 16:49 # 6
nupel307
I went to the craftsman said axle clearance said nothing would happen .. I wonder if nothing would happen ... I'm not comfortable actually.
08.05.2020 16:49 # 7
monur
[QUOTE = nupel307] I went to the master, said the axle gap, said nothing would happen ... I wonder if nothing would happen ... I'm not comfortable, actually. [/ QUOTE]
somersaults.
08.05.2020 16:49 # 8
toga406
you take notice of the warnings into your silence, go get confirmation from another master
