acill help plate is not removed :)
08.05.2020 17:23 # 1
mrb friends I have to disassemble because the plate of the car will change, but whatever the plate is stuck for 1 hour I did not disassemble the front plate was gone from god allah, but if the back plate was napping, I didn't pour hot water, I still await your help & nbsp;
08.05.2020 17:23 # 2
Alicilik
I also had APP plates bonding. The police said to disassemble or I will pull the car. I tried, the plate has no future with my hand. I'm in a hurry, the police don't leave. I took the screwdriver and wrapped it in a little cloth, and I smacked it. The end of the plate was opened. I could stretch it out with my hand, but I just leaned my leg on the tailgate and pulled the plate.
08.05.2020 17:23 # 3
I do not know, I did not do the back plate, the plate was folded, bent edges, but it does not come out even I tried it with a knife. There was no screwdriver flan.
08.05.2020 17:23 # 4
Alicilik
[QUOTE = mehmetmert16] I do not know I did not have to do it, the plate was folded back to the back plate bent the edges but it does not come out I even tried with a knife screwdriver flan did not solve it with something I do not know it does not work in hot water Do you know what to do? I was having a hard time. I was having a hard time, I said, I sometime leaned on the car and got support.
08.05.2020 17:23 # 5
Thanks, I am going to go there at last, let's look at the bidet.
08.05.2020 17:23 # 6
Alicilik
Well, scalpel solves your job, but you have to use it carefully. Good luck with.
08.05.2020 17:23 # 7
Let's see if I find it in the morning and I'll try it :)
08.05.2020 17:23 # 8
hsnsnl
My teacher, they have glued me with great melange. It is very hard to get it out. It happened in me. ;)
08.05.2020 17:23 # 9
let me have this in mind, thank you, I already take a cleanse, I will put the plate on it and put the plate on it again.
08.05.2020 17:23 # 10
akin__
If the silicone style is glued with something, the solution is easy. Thread the line on the back of the plate and pull it towards the other end. cutting the silicon :)
08.05.2020 17:23 # 11
Bugra
Hold the raised end of the plate with pliers or pincers and pull whatever the god has given to the attached end. then scrape the silicone or adhesive with the brush to damage the paint. I did this.
08.05.2020 17:23 # 12
I couldn't find the rope to you, but when you say cut a little bit with a scalpel, I took it off because you helped all of your friends.
