ACILL Cylinder upper cover Gasket oil leakage
08.05.2020 21:21 # 1
Umitydinc
Hello friends, I just joined you. I bought 2006 + 2011 vehicle. Expert de conta & nbsp; He said there is oil leakage. If you do not pay the price between 1500 and 1500, he said that he may charge 10000 expenses. Arac & nbsp; owner has changed 5 months & nbsp; said I have been driving the vehicle for 3 days under the car or on the engine oil leak & nbsp; no. Now, my question is, let me change that expert said to me like this & nbsp; or oil deposits in the previous change & nbsp; left right left left expert does it base guys give urgent tactics & nbsp;
08.05.2020 21:21 # 2
First of all, welcome to us. I wish you could use it without accident. A similar problem had been with me because the problem was from the eccentric seal, the cover was opened and opened again. First, have the engine washed well in a place that knows the job well, because places that do not know the job can cause trouble. There are 30-40 TL engine washers. After 100-150 TL, observe after that there may be residual oil residues as you said, probably there is a leak. Do the engine washing when the engine is cold. and a small intake of water, although some of them are sure that they will shut down the fuse and the engine ecu, may cause oxidation after 4-5 months of oxidation. it will be better if you add a photo. & nbsp;
