acill
08.05.2020 16:31 # 1
akkus50
I have a friend pejo 206 hdi I changed the diesel filter of the vehicle & nbsp; Bida did not work, but it was taken & nbsp; but the car may not be working
08.05.2020 16:31 # 2
yavuz25
First of all, welcome to our form. They couldn't get the air. Did you start a little longer?
08.05.2020 16:31 # 3
06OzGuR06
Bypass & nbsp; made with hand pump ?? & nbsp; How did you get your air?
08.05.2020 16:31 # 4
akkus50
yes & nbsp; done & nbsp; & nbsp; siprey is working but when it stops, they say it does not work with the impact sensor or something but there is nothing in the vehicle
08.05.2020 16:31 # 5
akkus50
air pumped from hand pump and tank
08.05.2020 16:31 # 6
yavuz25
I think it is a weather problem. Was the original part used.
08.05.2020 16:31 # 7
akkus50
No diesel, no problem & nbsp; no output from the pump
08.05.2020 16:31 # 8
akkus50
p 1505 in case of failure
08.05.2020 16:31 # 9
06OzGuR06
There is air in the system. No fuel.
08.05.2020 16:31 # 10
yavuz25
[QUOTE = 06ÖzGüR06] There is air in the system. No fuel. [/ QUOTE]
Exactly. Every man says he is a master, what are you going to do? "Dead" Butcher's word came again. "Smile"
08.05.2020 16:31 # 11
yavuz25
Start and try a little longer for the solution. "Wink" Can be solved.
08.05.2020 16:31 # 12
06OzGuR06
P1505- Idle air control system & nbsp; & nbsp;
this means the malfunction code.
08.05.2020 16:31 # 13
yavuz25
[QUOTE = 06ÖGGR06]
this means the fault code.
[/ QUOTE] This is
. "Clap"
08.05.2020 16:31 # 14
yavuz25
Thank you brother. "Wink"
08.05.2020 16:31 # 15
akkus50
not until the filter section
08.05.2020 16:31 # 16
akkus50
or the weather & nbsp; at least won't work & nbsp;
08.05.2020 16:31 # 17
06OzGuR06
Has any socket other than the fuel filter been removed?
Edit: So another & nbsp; Is there any action about the system?
06ÖZGüR06 2012-01-04 23:00:28
08.05.2020 16:31 # 18
akkus50
No, I was just replacing the diesel filter. I had no trouble in the vehicle before. It was just writing something like 1505 blows or something
08.05.2020 16:31 # 19
It is necessary to bleed again. According to the image, there is air in the filter. I think that if the pump is made while pressing Mars, it will be solved.
08.05.2020 16:31 # 20
06OzGuR06
[QUOTE = yavuz25] [QUOTE = 06ÖzGüR06] There is air in the system. No fuel. [/ QUOTE]
Exactly "Thumbs
Page : / 3
Peugeot Forums - Peugeot Fan Club © 2025
FromOwner.co.uk — Buy & Sell Directly from Owners in the UK. No dealers. No commissions. Just from owners.
