ACİLL 307 Gas Not Eating ..
08.05.2020 17:05 # 1
2006307
Hi guys, I have 307 1.4 16V LPGLi. When I run the car, it stops when I lightly press the gas while passing from the gas to the tube. I changed most of the things to the vehicle anyway. I don't know what's wrong with my motor brain.
08.05.2020 17:05 # 2
asilkatip
I have the same problem, brother, in this case it bothers me a lot, but I haven't found a solution yet. Even the car also kicks on it or coughs off
08.05.2020 17:05 # 3
ekinoks44
I have that same problem
08.05.2020 17:05 # 4
darkface
You can try cleaning the throat butterfly. I had such a problem before LPG installation. I cleaned the throat butterfly and the problem was solved. But be careful with your master, because it is a little expensive piece, this work needs to be done carefully. & Nbsp;
08.05.2020 17:05 # 5
guner38
There is a problem in the coil. I had the same problem. I changed it. I don't have a problem now. & nbsp;
08.05.2020 17:05 # 6
syz33
1-throat throttle
2-gas pump,
if it does this only on gasoline, second option I changed the engine of the gas pump
100 TL my money is gone 2. the day has been done again. TL, imported 200 TL
08.05.2020 17:05 # 7
ByHack
If he's doing it only on gasoline, I think he's likely to be a gas pump :(
15.07.2021 18:44 # 8
black_jeruz
Hello friends, let me resurrect the topic, I have a 307 1.6 automatic gasoline vehicle, when I load the gas at the first start, the vehicle does not eat gas, both in gasoline and LPG, the engine stutters and sometimes stops.
The processes I have done have changed, the coil and spark plugs have changed, there is no problem with the ignition, but the car is the same, what is the solution?
