Accumulation problem in 207 (emergency aid)
08.05.2020 17:34 # 1
aknard
friends, I open the issue to help a friend's son.
2011 triptronic 207 received 1.4 gasoline / tube vehicles last week. > As far as he says, there is an incredible accumulation in the vehicle, the vehicle does not go and stop even though it is pressed. >
08.05.2020 17:34 # 2
aknard
Could it be from the gearbox, friends? I need the opinions of friends who use auto especially ...: S
08.05.2020 17:34 # 3
It may be a transmission without stopping. But it is interesting that it does not fail. Your writings may also have symptoms of an ignition problem or an air intake problem (throat butterfly), but it should make a mistake. If it does not make the same problem in me, there may be a problem with fuel.
If there is a gearbox error, it should give automatic gear fault error.
If there is an ignition or throat butterfly failure, it should give an antipollution fault error. and in case of failure, the vehicle must be connected to the authorized service and connected to the pp2000 because the vehicle's warranty is likely to continue.
