Accumulation in Gas
08.05.2020 21:10 # 1
Frt-Aydin
Yes friends
When the vehicle is cold, it does not eat gas in gas or it stays or stops, and the normal problem disappears when it gets hot.
Misfire does not cause any trouble at idling, kicks start.
But there is no problem in the LPG, when it is cold, when you run on LPG or pass the LPG, there is nothing to stop.
08.05.2020 21:10 # 2
Karacocuk24
[QUOTE = Frt-Aydin] Yes friends
[/ QUOTE] I had a problem like this when I had a cold misfire in idle, but I was very frustrated with the wurth gasoline injector cleaner because it was only injector. ok but I think it should be used without the problem.
08.05.2020 21:10 # 3
Frt-Aydin
EYVALAH B DENIYIM
08.05.2020 21:10 # 4
Frt-Aydin
my problem has improved with brain calibration on the computer
