Accident
08.05.2020 20:09 # 1
mbjk1903
Good luck everybody, I lost the snow on the sidewalk. There is a gap in the dection.
08.05.2020 20:09 # 2
Let my teacher get past God protect you from the worst, if the rod head is broken, it will not turn right and left. Firstly, the table - rod head - rod shaft - z rot - hub and front axle carrier have control. varies by brand. They require 30-40 TL of labor for the replacement of the rod head, and then you will be forced to rot-balance the vehicle, around 50 TL.
08.05.2020 20:09 # 3
onlycihan
I do not think that there will be a lot of expenses for the past.
08.05.2020 20:09 # 4
mbjk1903
I made the tie rod rod tie rod workmanship tie rod setting all 125 rents thank you all
08.05.2020 20:09 # 5
samet206
Get past, you have teared cheap, something similar happened to me before, swing, axle repair, wheels, wheel change, I had a lot of expenses.
08.05.2020 20:09 # 6
OguzhanKucuk61
Get well soon hodja
08.05.2020 20:09 # 7
yigit_dark
Get well soon, God bless you.
08.05.2020 20:09 # 8
mbjk1903
Thank you all
08.05.2020 20:09 # 9
Oktkor
Get well soon.
08.05.2020 20:09 # 10
ggitaristt
Get well .. I did the same, only the right swing changed, I saved it cheaply ..
08.05.2020 20:09 # 11
Gokcesel
Get well soon.
