acceleration
08.05.2020 17:26 # 1
tongucuk
friends ak lamb's timing print pads flywheel vs & nbsp; all changed with original parts only & nbsp; there are 2 troubles 1st car I observed is trembling on the first departures & nbsp; such a problem has not been found before. does not immediately pick up speed, does not jump out like a gasoline vehicle, after about 5 seconds it gets the gas at speed & nbsp;
& nbsp; repairman friend & nbsp; says I'm shaking because I'm not used to diesel
& nbsp; He said that the engine was jerky in the first run, and the engine runs jerky in almost all of the 307 1.6 engines, so it is in its own car. & nbsp;
& nbsp; & Nbsp; do you think it may cause me to pick up speed on first departure & nbsp;
08.05.2020 17:26 # 2
ilyas
The tremor is generally present in most diesel vehicles. acceleration can be a little late in diesel. linea and 206 as a user, not like petrol. As the turbocharger's power transfer increases with the revs in the diesel, the vehicle will go up to 1750-2000 revolutions, but there is a slight recline when the revs increase.
08.05.2020 17:26 # 3
tongucuk
Thank you teacher, this is not a problem, can we say that the diesel engine is a habit?
08.05.2020 17:26 # 4
ilyas
this is my third diesel car that i use linea. kia cerato had 1.5 102 hp getz same car with the same engine that you say was pulling paw in 1 and 2 gear same thing is valid in 2010 connect 90 hp but linea is also bulky on departure. I know that the turbocharger and the gearbox used are related to gear intermediate acceleration.
08.05.2020 17:26 # 5
tongucuk
Thank you, manager, there is no problem.
08.05.2020 17:26 # 6
I think take a look at your vehicle's turbo, its pipes. He needs to shoot bastinism instantly. So, when you get into the gas, does something like black smoke come from the exhaust?
08.05.2020 17:26 # 7
Aziz
In Diesel Fiat (Linea), after 1700 revolutions, it feels like it is scorching late because the turbo is engaged. As far as I know, this is not the case for the diesel peugeot. As corn says, it should get instantly. & Nbsp;
If you just switched from gasoline, it seems to you that Diesel Tractor will be a bit of pleasure :)
08.05.2020 17:26 # 8
tongucuk
friends, problems have been resolved: engine vibration 1.6 hdi has always been in diesels caused by me during the tremor of departure. On the first departures he entered, the turbo had no & nbsp; role & nbsp;
& nbsp;
& nbsp; Thanks in advance to those who want to add to my articles and inform & nbsp;
08.05.2020 17:26 # 9
tongucuk
yes i was very strange about diesel after gas & nbsp; "Smile" & nbsp; 206 was touching & nbsp; but it did not stop & nbsp; "Big
08.05.2020 17:26 # 10
tongucuk
Thank you, Professor, will you examine the last issue I opened? Smile
08.05.2020 17:26 # 11
cerci07
[QUOTE = ramazanturan81] friends problems have been resolved: engine vibration 1.6 hdi diesel has always been in the departure caused by me in the departure. "# ff0000"> in these vehicles, the turbo has no & nbsp; role in the first take-offs after 140 km speed & nbsp;
& nbsp;
& nbsp; Thanks to those who want to add to my articles and inform them & nbsp; in advance. Even if you use the clutch, it may be the wrong material. It may be from the engine chocks. & nbsp; There is no other wake up to the vehicle. After the change, sometimes the vibration started and reversing started.
08.05.2020 17:26 # 12
tongucuk
Thank you, the manager was not very comfortable with me. I will go to garajturk for a while, let's have a good look at it.
08.05.2020 17:26 # 13
tongucuk
I do not have the opportunity to sew the tailor's ripper, but believe me, I will make small works on the bonnet and cover it right away.
08.05.2020 17:26 # 14
tongucuk
thank you can you come
08.05.2020 17:26 # 15
ZP105
The turbo shook badly, whoever said 140km
related to turbo cycle
If your vehicle shows turbo power after 2,000 revs, if you take off with as little gas as it can, the problem is
08.05.2020 17:26 # 16
Our master rocked 140 kmh beautiful. The turbo is usually activated from the point where the vehicle's engine produces maximum torque.
