ABS Problem Help ...
08.05.2020 16:00 # 1
slm friends again is a problem but it has been going on for a long time, they said it was normal, I said let me ask from here as you know I have 2001 model 1.6 Xr Platinium problem in me. If it is nice, I do not understand why this pedal hits the vehicle without slipping. Is there any problem in your vehicle when you are going on the road, it clicks on the brake, clicks on the brake, the sound is complete. They said no problem in his brain ...... ibrahim aslan 2011-08-15 23:35:20
08.05.2020 16:00 # 2
God, this is a very normal situation. Where's the problem?
You should not feel any vibration when the brakes are low. When it brakes too much, the abs will start as soon as any tire starts to lock. Abs doesn't work all the time. It activates only when the tire slides. Are you crazy in detail about how abs is?
08.05.2020 16:00 # 3
The purpose of abs is not to slide the tire, as Cem said
08.05.2020 16:00 # 4
[QUOTE = HuseyinTurk] The aim of abs is not to slide the tire, as Cem's brother said [/ QUOTE]
Yes, the purpose of abs as I am saying is already ...
When there is a small amount of curvature in the disks, shaking and shaking can be done when the brake is pressed. This event has nothing to do with abs. But when the friend said that he was replacing it at his disks, I would take this glaring look ...
08.05.2020 16:00 # 5
I think Ibrahim brother has no problem.
08.05.2020 16:00 # 6
If you say fortune-telling, come and bid it, I think you have a problem.
08.05.2020 16:00 # 7
plus I replaced it with its original parts, all VALEO ...
08.05.2020 16:00 # 8
[QUOTE = ibrahim Aslan] If you say fortune-telling, come on, bidet, you get it, I think this is a problem.
If the brake is pressed too hard, the abs will be activated. Does it make a truck when most of the brakes are low?
Or do the masters of the show cannot understand that this is a problem without experience ??? Or do you perceive or misinterpret you ???
Either so or so Sırıtma
the cecol 2011-08-16 00:11:30
08.05.2020 16:00 # 9
[QUOTE = ibrahim Aslan] plus I replaced it with its original parts, all VALEO ... [/ QUOTE]
Guys, I want to try my luck, too.
Even if Ibrahim bey is Valeo, those wheels will not slip as long as they are abs. Gülme
08.05.2020 16:00 # 10
I say it, no problem slipping, pedal shoots without slipping .....
08.05.2020 16:00 # 11
ewet this is making a truck and i mean it too cecoli brother ...
08.05.2020 16:00 # 12
the master may not understand, but when I connect it to the pc, I do not find anything, I do not find the problem, there is no problem in braking, it looks fine, sometimes it does print, I pull it, I do not press it again, and when I enter the mound, the ABS lamp is on when it lights up ....
08.05.2020 16:00 # 13
I didn't understand anything, because of this Sırıtma
08.05.2020 16:00 # 14
I couldn't explain or ...
08.05.2020 16:00 # 15
You also said the abs lamp is on. Abs lamp is not lit when it is malfunctioning.
08.05.2020 16:00 # 16
The ABS lamp lights up when I drop into the pit because of the sensors on the wheels.
08.05.2020 16:00 # 17
I read all the comments written to me, I was surprised and didn't understand anything ...
There seems to be no problem with your vehicle.
Maybe your tire size is very wide so it doesn't make any slip, but but the abs is not slipping anyway Confused
08.05.2020 16:00 # 18
so the tire is originally 14 ''
08.05.2020 16:00 # 19
Now I looked at the guide ABS lamp on the guide ABS: The anti-lock system has been activated ...
08.05.2020 16:00 # 20
Platinium
Everything may be normal, but nobody claims that these 306s are the same as other ABS vehicles, it has a very different abs from the others.
Page : / 2
