abs problem
08.05.2020 16:57 # 1
furkan111
The abs fault light of my newly bought vehicle is on fire, I went to the mechanic, he said everything looks normal, he plugged it into the computer and looked at the computer .... but the abs can not start in sudden brakes ... I wonder what else can be done to test the abs?
08.05.2020 16:57 # 2
pug206
There may be a problem in the abs brain, or there may be abs cables behind the wheel, they may be caused by them.
08.05.2020 16:57 # 3
furkan111
I understand how the repairers do not understand them, I do not understand at all, folks are repairing.
08.05.2020 16:57 # 4
sezar206
You don't understand under normal circumstances. Pedal on the slippery ground, pedaling under the vibrating foot.
08.05.2020 16:57 # 5
Barut
If it is working solidly it makes tremor normally when loaded on the brake.
08.05.2020 16:57 # 6
Cmoss06
If one of the ABS sensing sensors is faulty, the ABS light will come on and it must be checked.
08.05.2020 16:57 # 7
Bugra
As far as I know, if the ABS light is on, the ABS will not work, it will not be activated. & nbsp; If you have tried every way in bidet and couldn't find the reason, I think & nbsp; any accessories or xenon etc. against the originality of the vehicle. If you get something like and your abs is close to your brain, you can do it too.
08.05.2020 16:57 # 8
furkan111
yes, I have a xenon in my car.
