abs please help :(
08.05.2020 15:24 # 1
ugur_xs
My abs light is flashing, is it time for my pads to change?
08.05.2020 15:24 # 2
ose
I don't think it is lining. there must be a brain problem. What is your car though?
08.05.2020 15:24 # 3
ugur_xs
206 xs 1.6 16v
08.05.2020 15:24 # 4
ugur_xs
Bide, I heard such a thing in other cars. Even there is this in me. Maybe because he didn't do it so often.
08.05.2020 15:24 # 5
ose
Is there a cable connected to the pads?
08.05.2020 15:24 # 6
ose
Most of the vehicles have cable connected to the pad.
08.05.2020 15:24 # 7
mon
the tire pressures should not be low, then burn
08.05.2020 15:24 # 8
Does ABS burn from tire pressure? We learned one more thing!
08.05.2020 15:24 # 9
[QUOTE = mon] the tire pressures would be low at that time, but not low [/ QUOTE]
I think nothing will happen. because it has nothing to do with ...
The sensor of the abs at the top reads the rotation of the wheel. after all, if the tire air is low, it will freeze :))) I think you have a mistake ... if you want, you can cut your tire in half try and let it burn ???
In response to the friend who asked the question ...
abs light can generally burn when there is an electrical problem in the abs cables, sockets, wheel sensors, center or vehicle.
There is no connection of the abs lamp with the end of the pad. the lining warning lamp becomes separate. As it may not be in every model, it hangs the lining together and completes the cable circuit inside and lights the lining warning lamp. this is only seen when the brake is applied ...
the cecol 2011-05-07 15:00:35
08.05.2020 15:24 # 10
kitay
First of all, I recommend you to have the car connected to the machine. The malfunction can be from the sensor on the wheels, if it is in the brain, if the brain is defective, they repair the brain for 300 or 400 TL.
08.05.2020 15:24 # 11
voodoo
dust, etc., accumulated on the head of the abs sensors. It can be burned due to such reasons, it can also burn from the accumulator or there may be any electrical problem ... my advice is to review it beautifully ...
08.05.2020 15:24 # 12
ugur_xs
I have two computers connected to the computer. There was no problem with the abs system in both of them. Bid is like this. The abs brain has a xenon brain soon.
08.05.2020 15:24 # 13
was abs light burning when it was connected to a lot of information ???
08.05.2020 15:24 # 14
ugur_xs
It was not lit when it stopped and when I stopped it, it goes out
08.05.2020 15:24 # 15
d3Li
I heard that the xenon brain disrupted the abs brain, they said bole in the service.
08.05.2020 15:24 # 16
ismail ozdemir
the same problem happened in me, it was burning from time to time, when I stopped and run it, the last way went like this for 1-2 months, then it started to burn continuously and the abs was disabled, they said goturd the abs brain was malfunctioned, but they said that I did not find any operation, but I have not found any flukes in Istanbul but I found a price in Istanbul. I did not get it, I did not buy the prices abroad.
08.05.2020 15:24 # 17
ugur_xs
The problem is solved. I removed the xenon balance from the abs.
