abs malfunction
01.06.2020 10:45 # 1
metin70
Hello friends, when my car is warming up, it means that the malfunction lights up when both driving and hot weather remain. Abs is disabled. When I connect it to the computer, it does not give any malfunction code. The user said the brain malfunction and said the amount between 300 and 850. What do you think?
02.06.2020 09:50 # 2
If it does, the sensor tip may be defective. It is necessary to check the sockets and the serensor. no brain malfunction is found immediately. If there is a problem in the brain, it constantly burns. I would recommend you to have the diagnostic device checked with the original device.
02.06.2020 10:31 # 3
metin70
The fault finding device was not original.
02.06.2020 12:11 # 4
non-original devices can not see.
05.06.2020 09:04 # 5
sercan23
I recently went because my abs light was on, it turned out that there was a disconnection in the sensor cable on the front left wheel, it was repaired, it was replaced with solder, it was fixed. If it is repairable with solder, the problem is, but do not let the brain blindly hand over to the brain, as I said it is not a thing when the abs brain is easily broken on the front left.
05.06.2020 09:06 # 6
sercan23
drowsy i wrote a little transposed I hope you understand sorry &# 128584; &# 128517;
05.06.2020 13:17 # 7
metin70
What do you mean, thank you very much.
