Abs lights on after xenon |
| 08.05.2020 21:04 | # 1 |
But when I turn on the headlights, after a while, the battery lamp first turns on, then the abs airbag lamps turn off, the vehicle goes into fault mode, and finally the electricity cuts off. I stayed on the road several times.
| 08.05.2020 21:04 | # 2 |
sonerkyl |
Disassemble the xenons, my brother, take the led type bulbs, the problem is obviously not a problem for the electrical parts.
| 08.05.2020 21:04 | # 3 |
[QUOTE = sonerkyl] Disassemble the xenons, brother, take the led bulbs, the problem is obviously not a problem for the electrical parts. I don't want to frustrate xenos, is there anybody who knows a solution of this?
| 08.05.2020 21:04 | # 4 |
Would you try to cover the ballast of the xenons with something like leather and rubber? |
| 08.05.2020 21:04 | # 5 |
[QUOTE = pusutr] Would you try and cover the ballast of the xenons with something like leather or rubber? [/ QUOTE] I'll try it, thanks.
| 08.05.2020 21:04 | # 6 |
sonerkyl |
In general, poor quality products open to this problem. I still recommend you to wear led type products.
| 08.05.2020 21:04 | # 7 |
[QUOTE = sonerkyl] in general, poor quality products open to this problem. I still recommend you to wear led type products. [/ QUOTE] The reason why I prefer LED is this; I have read the comments that xenons provide higher illumination than leds, they are in the lenses on the sites, but this seems to be my remover
