ABS LIGHT IS ON
08.05.2020 21:30 # 1
Dna_probe
I bought the vehicle today. I knew that the ABS light was on, I was surprised when I was just turning the car with 40 km, I was surprised at what the car was beating, the brakes of the car are not very good and also it pulls from the light to the left. If anyone from Konya can first recommend me a master? both for these problems and for general maintenance. And friends I listen if anyone knows how to solve these problems
307 1.6 XT GASOLINE & LPG
Dna_prob to 2020-04-02 00:38:53
08.05.2020 21:30 # 2
KILIC
This situation can also be made of tires. If the tires are too old, no road holding remains, it has become stiff. In addition, if it is filled with excess air, the handling is poor again.
08.05.2020 21:30 # 3
EmSul
The abs light may be on because the brakes are over, when it is connected to the computer, it becomes clear.
08.05.2020 21:30 # 4
Dna_probe
brake and ABS ok 2 sensor changed pads in the same way.
I also changed the oil of the oil and air filters, but I realized that today, when I first started the car, it was black smoke, I looked a little bit, they put a little bit of oil on the avalanche. Do you think he's doing it because of it and I have one more question, guys. There is a problem in the signal arm, it does not come down to the pressure, it falls to the left. What should we do?
08.05.2020 21:30 # 5
When the engine is cold for the first time, black smoke is usually caused by petrol injectors. it must be disassembled and cleaned. is the most beautiful original software control. I wish it had an effect on the brakes if you changed the brake hydraulic oil. There is a white part in the signal arm, because it has completed its life, the arm is falling. There are yarler that repairs, of course, you need to find it or you will get the full headlight signal arm because of the room lining. If you can find it from this piece, it can be changed individually.
08.05.2020 21:30 # 6
Dna_probe
First of all, thanks Soner.
Are there people trying or doing hydraulic oil and injection cleaning in the forum?
or if someone is making a video, I have a key and I can try it myself.
