ABS Light Burned After Halogen Bulb Replacement
08.05.2020 21:15 # 1
soydan
Hello, Peugeot Family. I replaced my car's halogen short bulbs with H7 philips xtreme vision 130% bulbs. Approximately 30 km after the change, the ABS light came on and the warning "ABS brake system is faulty". I showed it to the electrician, plugged it into the computer, and cleared the malfunction. As far as I can see in the malfunction, he was writing warning information about the short circuit. The electrician said, if it happens again, there is a problem in the ABS brain, we will send it for repair. Can anyone give this information together with their solution if they are experiencing this problem? My vehicle 308 2010 1.6 hdi 110 hp comfort pack manual.
08.05.2020 21:15 # 2
I think it was a coincidence that if it made a short circuit, the bulb would throw the fuse, probably water could have entered and made oxide in one of the abs sensor sockets. I suggest you disconnect the sockets and clean them with contact oil-free spray. I also recommend you to check your fuses.
08.05.2020 21:15 # 3
soydan
[QUOTE = sonerkyl] I think it was a coincidence, if it was short-circuited, the bulb would throw a fuse, probably water had entered and oxidized in one of the abs sensor sockets. I suggest you disconnect the sockets and clean them with contact oil-free spray. I also recommend you to check your fuses. [/ QUOTE]
What you said may be true because the ABS light is not on right now, I think it has improved.
08.05.2020 21:15 # 4
Probably, my teacher has been rainy in the last few weeks.
