abs light and airbag light are on
08.05.2020 15:23 # 1
ugur_xs
first greetings to all, the 2004 model xs model 206's airbag is on and then the abs light is on, the speed hand does not work when I stop and run it, but it does this occasionally and upset the human nerves Wall I would be glad if you help me
08.05.2020 15:23 # 2
First of all, you need to introduce yourself to our Members, as each new member does.
08.05.2020 15:23 # 3
ugur_xs
I already introduced
08.05.2020 15:23 # 4
Sayoka
[QUOTE = ugur_xs] first greetings to everyone, the airbag lights up occasionally on the 2004 model xs model 206, and then the abs light is on, the speed hand does not work when I stop and run it, but occasionally does it and upset the human nerve Wall I would be glad if you help me [/ QUOTE]
Hello, first of all, the reason for the burning of the air light is a few. For the first control to be done effectively, after the fault reading with the device in the authorized services we call PPS device, the answer to all the problems will come from there. The airbag light usually comes on due to the lack of contact from the underarm sockets, but it is a high probability that the Coom2000 signal arm may need to be replaced.
08.05.2020 15:23 # 5
ugur_xs
So why does the ABS burn?
08.05.2020 15:23 # 6
emre17286
I HAVE MADE THEIR CABLES UNDER THE SEAT, I THINK I HAVE ME SURVED
08.05.2020 15:23 # 7
[QUOTE = emre17286] UNDER THE SEAT WAS MADE FROM THE SHIRT CABLES I THINK I HAVE PROBLEMED WITH A PROBLEM [/ QUOTE]
If only airbag is right, you are right, but the abs is burning in heat, and does not work in the face indicator.
I think it might be a situation related to an illness ... an electrical problem. is the battery safe?
08.05.2020 15:23 # 8
emre17286
[QUOTE = CeCoLi] [QUOTE = emre17286] UNDER THE SEAT WAS MADE FROM KI CABLES FOR ME, THAT I HAVE SEEN WITH A PROBLEM [/ QUOTE]
FROM THE RIGHT OF THE RIGHT OF THE RIGHT TO THE BEST ELECTRIC MASTER OF THE RIGHT OF THE RIGHT ELECTRICAL PROBLEM 80%, I WOULD LIKE TO SHOW THE BODY OF THE GOOD CONSIDERING BEFORE GIVING BAD RESULTS.
08.05.2020 15:23 # 9
nice brother i would like to use big letters Sırıtma Maybe if you don't know, using big letters is like swearing as well :)) be crazy
08.05.2020 15:23 # 10
emre17286
[QUOTE = CeCoLi] nice brother I would like to use big letters Sırıtma Maybe if you don't know, using big letters is like swearing as well :)) get crazy [/ QUOTE]
oke i didn't know i learned
08.05.2020 15:23 # 11
trtolgi
I think it should be from battery
08.05.2020 15:23 # 12
You're welcome. keep it in mind in such forums :))
08.05.2020 15:23 # 13
emre17286
I would like [QUOTE = CeCoLi]. keep this in mind in such forums:)) [/ QUOTE]
oke thank you it was good i learned Göz Kırpma
08.05.2020 15:23 # 14
cnrars
I have the same problem, the service changed the battery, no problem. can be from battery.
08.05.2020 15:23 # 15
sedat23
What was my car dynamo? I don't remember your name. I could make a room once.
08.05.2020 15:23 # 16
flash296
A solder that performs a chassis in the indicator can do this by touching the wire. You connect the car to the computer, the computer will tell you where there is an error. There is no need to go to the service. go to them. your solution is connecting to the device. If the device does not malfunction, there is definitely a hood or a solder that breaks ...
08.05.2020 15:23 # 17
who knows maybe from "oke" Dil Çıkarma
08.05.2020 15:23 # 18
inceyasar
man check your fuses can detect a fuse threw the car
08.05.2020 15:23 # 19
emin15
When the mileage sensor malfunctioning airbag and abs light comes on, the system automatically gives these two faults when there is no speed information in the vehicle.
08.05.2020 15:23 # 20
lifat
Hello there. First of all, I think it is necessary to find out what the malfunction is by connecting it to the tester as I said in my friends. If you want, I always went to the special service's phone and they have original test devices of peugeot. 0216 540 56 51 ömer master.
Page : / 2
