ABS LIGHT !!
08.05.2020 16:46 # 1
feline
While my friends driving the car 206 diesel 2006 model car, I wait until the stop light goes out, then when starting, the abs light is on momentarily then turns off when turning the full contact I just realized that I do not have a problem or does it happen to everyone ???
If I ask, those who have the same car can pay attention and tell me when they are running, I get stuck in the moment when it is running, it doesn't flash, but it doesn't seem like it hasn't happened before.
thank you in advance
08.05.2020 16:46 # 2
oguzhan29
when you turn on the ignition in diesel vehicles while starting the car, some lamps will light up and you will start after they go out
08.05.2020 16:46 # 3
feline
actual
08.05.2020 16:46 # 4
fatihgg
It was the same 307 1.4h. I get the contact on the star, the lights are coming to an end, the marsa stops within 1-2 seconds of the pressure. Look at me, I was furious: How are you friends?
08.05.2020 16:46 # 5
feline
yeah that's how I got it & nbsp; :))
08.05.2020 16:46 # 6
omer_tarsus
last year it was in me so the service made for 500 tl
08.05.2020 16:46 # 7
omer_tarsus
[QUOTE = ömer_tarsus] last year was the case for me, the service made for 500 tl [/ QUOTE]
something normal friends, I have 206 diesel for 3 years and always has been. This is not a problem :)
08.05.2020 16:46 # 8
feline
well, your first message was a joke :)
08.05.2020 16:46 # 9
toga406
The important thing is that the light is dimmed while using it. If it is on, apply sudden braking, if the abs vibrates to the brake pedal, it means that it is activated.
08.05.2020 16:46 # 10
gngburak
I have no abs master, said the vehicle 206 2005mod. x-line & nbsp;
& nbsp;
The ABS lamp is on after the
contact is activated. Goes off after 3 seconds & nbsp; I couldn't make any kind of logic, what is this?
08.05.2020 16:46 # 11
metin
When we start the vehicle for the first time, the brain of the vehicle controls the equipment such as abs, airbag etc. when the contact is opened. It is normal for the lights to come on during this check. These lights go out after starting the car. & Nbsp;
If the stop text flashes 3 times after starting the car and the abs, airbag etc. lamp is on, it indicates that there is a malfunction. & Nbsp;
For example, if we start the car for the first time, if the airbag lamp and the stop lamp flash 3 times, it means there is a problem in one of the airbags.
08.05.2020 16:46 # 12
gngburak
Thank you very much, my teacher was very informative for me
13.01.2022 10:51 # 13
erolgfb
Hello friends,
I have 2005 307 1.4 hdi xr, when I turned it on yesterday morning, the abs light came on and went off with a stop for about 2 seconds. Is it a problem?
13.01.2022 11:22 # 14
it has to be on all the time for it to be a problem, sir. If it doesn't go off within 5 seconds at first start-up, the problem is the vehicle is doing a system check. no problem
13.01.2022 23:12 # 15
erolgfb
Thank you. I hope there will be no problems.
