ABS light
08.05.2020 15:36 # 1
murat deniz
friends I have a 2004 model 206 x-line 1.4 gasoline car. When I opened the ignition for the first time today, I saw that the abs light was on beside the airbag light. When I turned the ignition to the second stage to start again in the evening, the abs light came on again. I knew that my car had no abs until now. I don't understand where the light came from if there was no abs. I would be glad if they share friends with knowledge on the subject. thanks for your answers .. the albaydemirc 2011-06-14 08:33:58
08.05.2020 15:36 # 2
fTh206
I do not have abs in the x-lines, I know I have got it wrong
08.05.2020 15:36 # 3
My friend is the vehicle your desire model?
my car desire model. For example, my vehicle has an EBD. but once I got the ABS light on. God said there is no ABS in my vehicle, but. I took it to the authorized service. As the EBD is supported, they said that the brake system fuse light turns on the ABS light. Insurance changed, the problem is over.
If your vehicle is a desire model, it is an insurance problem caused by EBD.
08.05.2020 15:36 # 4
Kemanyak
There are no friends if it is not lit. If the ABS light is on, the detectors do not detect the rotation. Or one of the cables or sockets may be oxidized-damaged. I say check it out. Stop the car on the flat road, then start without turning the steering wheel will go out for a while if there is no malfunction in the cables ...
08.05.2020 15:36 # 5
Friends I Have ABS In My Vehicle But It May Not Be In All X-LINE 206s.
I have a close friend, if you look at it, the vehicle has 1.4 gasoline X-LINE but no ABS ...
The Best Way To Understand This If You Open The Hood And If There Is Anything Above The Left Headlight, Your Vehicle Is ABS.
08.05.2020 15:36 # 6
murat deniz
[QUOTE = maverick sbd] is my friend the vehicle your desire model?
maverick is not my vehicle desire x-line model. Maybe there was a problem like you.
08.05.2020 15:36 # 7
murat deniz
[QUOTE = Violin] There are no friends, it will not light up ... If the ABS light is on, the detectors do not detect the rotation. Or one of the cables or sockets may be oxidized-damaged. I say check it out. Stop the car on the straight road, then start without turning the steering wheel will go out for a while, if there is no malfunction in the cables ... [/ QUOTE]
No it was not burned while driving. When I first turned the ignition, it gave warning in the 2nd stage and then went out when I started it. The same thing happened twice yesterday, but today it never did.
08.05.2020 15:36 # 8
Does the ABS that appears in the picture become the brain?
[QUOTE = AlbaYDemircaN] Friends I Have ABS in My Vehicle But May Not All X-LINE 206's.
08.05.2020 15:36 # 9
[QUOTE = badires] Does the ABS in the picture become the brain?
Yes ...
08.05.2020 15:36 # 10
OK. Something like that was standing in that corner of my car, but I didn't know what it was. Thanks to you, I learned it too.
08.05.2020 15:36 # 11
murat deniz
What did we learn from the forum? I mean there is no such part in my car, there is no ABS :) thanks ..
