Abs Light
08.05.2020 19:11 # 1
KILIC
Greetings friends. As you know, I got 307 last week and there are minor problems. For example, when I turn the ignition, the abs light does not light up. I searched the whole form, Google, but I always encounter the same problem, all of them complain that the abs beam lights up, but when my distress turns the contact, the airbag etc lights up but the abs light does not burn. I wonder if it might have blown insurance etc. Abs is working by the way, I tested it and it does not give any warning with abs.
08.05.2020 19:11 # 2
Canberk35
It should light up in the level before starting and turn off in about 1 second after starting. Actually, it is not a big problem that the ABS light does not flash there. If there is an error, it appears on the road computer of the vehicle. Maybe there is a problem in the illumination of the indicator. That's why it's not burning.
08.05.2020 19:11 # 3
KILIC
Exactly, if I have insurance, maybe the fuse was blown, the fog lamps were not burning, because the fuse was blown. But it is best to show the electrician that he hesitates not to burn while he is working.
