ABS Lamp Problem Flashing
08.05.2020 20:51 # 1
genieril
Hello friends, let me explain the problem for a long time, maybe a tip is caught in the meantime: D
The 2006 model 206 1.4HDI Feeline's ABS lamp burned down while stopping about 3 months ago, I was surprised then I looked at it the next day when I got on the morning it was not lit. Anyway, a few weeks passed, I said it would be the last time it burned again and it went out after a few days .. the same process has been repeated a few more times but the difference that caught my attention was the extinction time and the abs lamp has been on for the last 2-3 weeks. I noticed that it turned out when I left the parking lot right or left a few times, but it could be a coincidence, it did not go out when I deliberately broke by breaking, but after the vehicle first started, the lamp that lights up after the parking maneuvers is turned off when it leaves the road, it usually burns when it goes through the bump or pit and does not go out . Last situation, the lamp that had been lit for 2-3 weeks yesterday, when I got out of the parking lot, I looked at it, it went out, but after 500mt, it said beep.
In the meantime, in the last maintenance, I changed the disc and pads a month ago, I changed the left front rear balls because the light hum started in the previous month, but I thought that it would be fixed, but it did not.
In the meantime, when I told the master, he said from the brain, I did not have a chance to look at the malfunction code, I said okay since I did not want to handle the brain or something.
It's been a little long, but what are your ideas? Is there anyone you can suggest about this in Izmir? I will say that if there were no flashes, it would be a brain, but it seems to me that something else is happening.
I cannot see the error code with torque lite from the Bidet bluetooth ODB II adapter. The ECU says no registration, no history or active registration.
It's been long, but thanks in advance.
08.05.2020 20:51 # 2
talip206
You say it burns when I enter the pit. It is likely that one of the sockets has loosened or made oxide. It is necessary to follow the abs cables and check the connection sockets. I don't think there is a problem with the brain.
08.05.2020 20:51 # 3
genieril
I hope it was caused by that kind of thing, but is there a master you can recommend in Izmir?
08.05.2020 20:51 # 4
x571
[QUOTE = genieril] I hope it was caused by that kind of thing, so is there any master you can recommend in Izmir? [/ QUOTE]
it is a socket problem.
08.05.2020 20:51 # 5
ersin61
Dude my previous vehicle 206 had a similar situation. Abs cable was slightly protruding in the place that corresponds to the front of the Amartisor over time, it had been worn on the left or tire turns due to rubbing. The wires inside it began to tear over time. I paid a fee of .20-30 TL 1-2 years ago manual labor room. The important thing is to find the place where it is cut or friction or as the friends say, there may be socket looseness.
03.04.2023 18:45 # 6
osseyrek
Hello
I have the same problem. My car 206+ 1.4 hdi abs lamp is blinking intermittently.
Did you solve the situation
17.02.2024 04:38 # 7
Stcngnr28
I have the same problem. Did you solve it?
24.02.2024 22:00 # 8
Oskiwow
I still can't figure it out, and the examination is coming up. I had it checked a couple of times, and they said it was due to the brain. The brain was replaced twice, and the problem persisted. I had the old brain put back in. I would be very grateful if someone could help.
