ABS lamp burned
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Bipper
08.05.2020 16:33 # 1
fantom
One day, when I was going on the road, suddenly the ABS lamp came on. What should I do? They called the service, they said we need to see. Did you meet?
08.05.2020 16:33 # 2
yavuz25
Believe me, whatever I say will be lies. Sensors, brake brain, short circuit, abs brain, etc. etc. It would be best to look at the service. It will not be a joke of abs as soon as possible. "Wink"
08.05.2020 16:33 # 3
06OzGuR06
Connecting to the computer would be the best way of service seems "Big
08.05.2020 16:33 # 4
yavuz25
[QUOTE = 06EZGÜR06] It would be best to connect to the computer the service path appears "Big [/ QUOTE]
they say money is stuck together. "T
08.05.2020 16:33 # 5
yavuz25
I don't like this nature of the pejo most. "Angry"
08.05.2020 16:33 # 6
racer50
dude what you are going to do is to connect it to the computer, if there is no sensor etc problem, it will give abs fault or abs relay error service will change 1200tl you will disassemble the solders you will disassemble if the job is coming from you, coal wa in the section where the relay is, you can finish it, I will make an electrician, I will make a fewer ones, I will make an electrician, and I will make a fewer ones. They want about 300 workmanship.
08.05.2020 16:33 # 7
peugeotefe
When you say abs role, you can explain the subject, I don't understand very much, does it have a coal in it? Rolein solder my solder ??
08.05.2020 16:33 # 8
yavuz25
[QUOTE = peugeotefe] When you say the role of Abs, you can explain the issue. Role is soldering my solder ?? [/ QUOTE]
"Shocked" "Thumbs
08.05.2020 16:33 # 9
efsanemurat
friends, I pulled the handbrake yesterday, it was very cold in the air -15 hours, the handbrake was left in that cold when I arrived and when I started the car, it turned out to be abs fault, I went 2km on the information screen, the text disappeared spontaneously. almost no tires were spinning from the snow now everything is normal no problem.
08.05.2020 16:33 # 10
djchaos
There is a socket under the seat of the front passenger and driver of the 307s when it loosens over time or it becomes contactless. If there are the same system in the bippers, check it can be in the sockets as usual sensor socket communication :))
08.05.2020 16:33 # 11
djchaos
[QUOTE = legend] my friends, I pulled the hand brake yesterday, it was very cold in the air -15 hours like 2 hours hand brake had been pulled in that cold when I came and started the car, it turned out to be abs fault. There was a lot of snow in the car, the tires were not turning from the snow, now everything is normal, there is no problem. [/ QUO & nbsp;
Look under the driver or passenger seats.
08.05.2020 16:33 # 12
erkerd5429
If I thought I touched the brake a little more than 10 days ago, I stopped spontaneously while looking at the ground to hit the record.
08.05.2020 16:33 # 13
06OzGuR06
[QUOTE = erkerd5429] If I thought that I touched the brake for about 10 days ago, I looked at the ground to hit the record, I stopped spontaneously, got off the lights, wrote an abs fault, went home, half an hour after stopping, I started the car, I did not understand why the light did not light up [/ QUOTE]
< br>
ABS has failed and has been disabled due to slipping & nbsp; There is a problem in the system, which means you can take a look at
if you want a good master. "Smile" Reviews
08.05.2020 16:33 # 14
yavuz25
[QUOTE = 06ÖZGÜR06] [QUOTE = erkerd5429] I stood spontaneously while looking at the ground to hit the record if I thought I touched the brake for about 10 days ago, got up from the lights, wrote abs fault, went home, I stopped the car half an hour after I stopped, I did not understand why the light did not light up [/ QUOTE] ]
ABS has failed and is disabled due to slipping & nbsp; There is a problem in the system, which means you can take a look at
"Clap" Just like my brother said. Abs is a vital piece. < img src = "smileys / smiley2.gif" border = "0" alt = "Wink" title = "Wink" />
08.05.2020 16:33 # 15
racer50
Efe brother, the fault code that falls on the computer is like that.
08.05.2020 16:33 # 16
peugeotefe
I understand that master has a lot to learn.
08.05.2020 16:33 # 17
kudret_yildirim
I know that any malfunction in the abs system does not affect the vehicle's braking system. Of course, I recommend you have it repaired as soon as possible, but during this time, you will only use it like a car without ABS. I hope there will be no costly repairs ...
08.05.2020 16:33 # 18
yavuz25
[QUOTE = racer50] efe brother knows how the malfunction code fell on the computer.
the picture has opened the right side, but the dynamos there is coal, the left side is already in the form of a plate. >
thanks my brother. "Smile" < / div>
08.05.2020 16:33 # 19
yavuz25
[QUOTE = kudret_yildirim] I know that any malfunction in the abs system does not affect the braking system of the vehicle. Of course, I recommend you have it repaired as soon as possible, but during this time, you will only use it like a car without ABS. I hope there will be no costly repairs ... [/ QUOTE]
"Thumbs Reviews
08.05.2020 16:33 # 20
conteo
While driving on the straight road, abs heat burned on my 207 vehicle, we went to the service. It is cıkıyor. Sensors and rear ball checked no problem found & nbsp; Now the brain and the cables going to the brain will be checked.
Page : / 2
