ABS Installation
08.05.2020 15:27 # 1
vbmaster
Dear members ;
As you know, Roland Garros is specially produced but 2000 models do not have ABS. Can I have it installed later. Do I get efficiency and what is the cost? Will there be a safety problem vs not holding the brakes after installation?
08.05.2020 15:27 # 2
Haksen016
If the vehicle has a preparation in the infrastructure, it will be appreciated, but the cost will be very high, it is much more reasonable to buy an abs vehicle, if you say it should be abs. I think it makes no sense to have it fitted to a vehicle later.
08.05.2020 15:27 # 3
vbmaster
I'm very happy with the car, the only thing missing is abs
08.05.2020 15:27 # 4
Haksen016
I think if you are very satisfied with the car, do not enjoy the abs, vehicles are in your opinion. It makes more sense to buy a high model vehicle with abs.
08.05.2020 15:27 # 5
iibrahimm
What advantage of ABS do you expect personally I think I can cancel ABS even if I can cancel ABS extends the braking distance too
08.05.2020 15:27 # 6
vbmaster
interesting :) I want the opposite, just because of security, can you explain a little bit?
08.05.2020 15:27 # 7
metin
Last regulation in Tüvtürk Vehicle Inspection Defects
In vehicle inspection, canceling ABS of vehicles manufactured with Anti-Blocking System (ABS) or installing ABS without ex-technical approval on vehicles manufactured without factory ABS will be considered as “heavy defect”.
According to the previous examination, vehicles with a low mileage will be considered as "slightly flawed", vehicles without rear shock absorbers, tires missing, or tires of different sizes on the same axle, with no windshield demisting system working.
According to the information received, according to the “Table of Defects to be Applied in 2011-2012” that will be valid from tomorrow, the amendments were made in the criteria for the vehicles to be considered as "unsafe", "seriously flawed" and "slightly flawed".
Accordingly, the absence or malfunction of the vehicles' ABS, canceling the ABS of the vehicles manufactured with ex-factory ABS or installing ABS without the technical approval for vehicles produced without the factory ex-factory will be considered as “heavy defect”.
With the new defect arrangement, ABS of passenger and load-bearing M2, M3, N2, N3, O3 and O4 class commercial vehicles produced with ABS are manufactured without ABS, in contrary to the technical regulations, although they must be in operation and not canceled. It will be ensured that the modified vehicles, especially the M2 class minibus, M3 class bus and O4 class trailers, which are mounted on ABS and without technical approval, will be detected during the vehicle inspection and get their technical approval.
text 2011-05-22 00:17:37
08.05.2020 15:27 # 8
oguzhan29
thanks for sharing, let's be knowledgeable friends, no matter how the car came out of the factory, then pay no penalty for nothing, or else you can go to the tire enlargement instead, or if you want to stop the disk enlargement at a short distance, but everybody says the original whatever it is but you still know
08.05.2020 15:27 # 9
ose
[QUOTE = vbmaster] interesting :) I want the other way around just because of security, can you explain a little? [/ QUOTE]
inspection was hit. It is true that the ABS extends the braking distance, but the abs does not engage unless you press the pedal hard depending on the usage, or rather the abs does not engage unless the wheels are involved in what we call sledding. in this way, the braking distance does not increase in use. The biggest advantage of Abs is that it does not lock the wheels in situations that require us to brake suddenly, it allows us to dominate the vehicle and keeps the control, that is, at the wheel.
08.05.2020 15:27 # 10
[QUOTE = vbmaster] I'm very happy with the car, the only thing is abs [/ QUOTE]
Take it from me, bro.
It hurts me that there is not only ABS in my 2000 model 206 XT.
08.05.2020 15:27 # 11
metin
[QUOTE = oguzhan29] thanks for sharing, let's be knowledgeable friends, no matter how the car left the factory, then pay nothing in vain or else you can go to the tire enlargement instead or if you want to stop the disk enlargement at a short distance but still everyone says the original what it is, but you still know it [/ QUOTE]
yes, they make the vehicle's motor braking system according to it, and some friends increase the power of the engine, but they have difficulty stopping because they do not make the braking system accordingly.
08.05.2020 15:27 # 12
tigerland
Put the ABS on the car, put 2-3 thousand on top of it, take a 2005 model RG sand color, I think it makes more sense. I also don't think the ABS shortened the braking distance of the vehicle. the tire comes into play if it slips abs.
A vehicle stopped suddenly in front of me this winter, and I had to apply the brakes, and the abs would have stepped directly, I would have slid from behind. I think ABS is a must .. tigerland 2011-05-22 10:27:51
08.05.2020 15:27 # 13
ismail ozdemir
[QUOTE = iibrahimm] What advantages do you expect from abs? Personally, I think even if I can cancel abs, I would like to cancel it so it extends the braking distance.
i have 2002 pejo 307xt abs brain malfunction did not find out yet :) suan vehicle abs ex
08.05.2020 15:27 # 14
metin
[QUOTE = beyazzzzz] [QUOTE = iibrahimm] What advantage do you expect from abs personally I think even canceling if I can cancel abs extends braking distance too much
I have 2002 pejo 307xt abs brain malfunction and I have not found it yet :) suan vehicle abs abs [/ QUOTE]
Did you contact peugeot efe for dating?
08.05.2020 15:27 # 15
ismail ozdemir
They called but the price came a little high, obviously I am stuck right now so I have to manage 1-2 months
