ABS FAULT
08.05.2020 14:10 # 1
"Don't "Don't "Embarrassed"
& nbsp;
dear friends,
& nbsp;
ABS FAULT
2004 & nbsp; model & nbsp; 307 activated ABS as soon as it applied the brake. Then the abs fault lamp; & nbsp; burned and extinguished.
& nbsp;
I went to the service, they said we will disassemble and look; The lamp has never turned off after they have been removed, and now they say that the & nbsp; abs sensor and the axle ball will change.
& nbsp;
Could there be another reason for the malfunction? Will these changes cost £ 350?
& nbsp;
I hope your answers will help other friends who come here, thanks in advance.
08.05.2020 14:10 # 2
First of all, let me tell you that the axle ball has changed without any need, and the modified axle is located in the oil between the gearbox output and the wheel axle head for the progress of a very different vehicle. 70 troll abs oil is an event such as abs wire and there is 65 tl price. Let's come to your problem.
08.05.2020 14:10 # 3
coyote26
I agree with you, brother, he gives the error mostly on the brake discs, I personally lived, and the lamp went out on his own.
08.05.2020 14:10 # 4
kocvizyon
my brother, if there are sockets under the right armpit
08.05.2020 14:10 # 5
peugeotefe
It is useful to connect your vehicle to the test device and see the malfunction, I do not think that the abs will be related to the end of the brake disc.
