abs fault
08.05.2020 14:09 # 1
erol
Hello, I have a new 2002 model 307 xt. My first car has a problem with my car. I will be glad if you help me. Firstly, service peouget services are simple but very expensive service options to solve the event with such expensive service. an airbag fault indicator appears on my car. why could it be. my second question. Mekezi lock is my ignition key is flat, so when I press the central lock button after starting the car, the castles do not lock. I don't have an inmoblyzer. I have a 307 remote key in my car. I'm using the key flat.
I thanked for everything.
08.05.2020 14:09 # 2
HakanGokdemir
Our members who have completed their new membership and entered the forum, please introduce yourself in the "Let's Know Our Members" section, you have to follow this rule to create a chat environment among the members who know each other in the forum.
New Member Promotion Information Form;
1.- Your name and surname :
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10. Which county y name a İlda here:
11.- Your MSN name picture:
It is better for you to fill all the information completely
will help us to get to know
08.05.2020 14:09 # 3
emredeniz
1.- Your name , surname : Emre Deniz
2.- Your age: 25
3.- Your vehicle (Brand, model): 206+ 2010
4.- Your Hobbies: Football, Highway :)
5.- Your Profession: Civil Engineer
6.- Where did you hear about the site: yusuf ziya taslica (yzt06)
7.- Your Blood Group: ARH +
8.- Your Sign: Sagittarius
9.- The team you support: Beşiktaş
10. Which county y name a İlda here: Ankara, Dikmen
11. r MSN name here: emredeniz1985@hotmail.co
08.05.2020 14:09 # 4
Serkanbo
[QUOTE = erol] hello i have a new 2002 model 307 xt my first car i have a problem in my car i will be glad if you help me. Firstly, service peouget services are simple but very expensive service options to solve the event with such expensive service. an airbag fault indicator appears on my car. why could it be. my second question. Mekezi lock is my ignition key is flat, so when I press the central lock button after starting the car, the castles do not lock. I don't have an inmoblyzer. I have a 307 remote key in my car. I'm using the key flat.
Thank you for everything.
If you're getting an ABS breaking system fault error, this was sometime in me. After 2-3 days, the clutch pump failed. When replacing the clutch pump in the service, they added additional hydraulic oil to the brakes, and this error message and warning lamp did not come on again. Reviews
08.05.2020 14:09 # 5
Eyup Duygun
If you look at the fault record in one of the special peugeot services, we can answer more clearly. There is definitely an immobilizer in your vehicle, but if the button on the top of the console does not work, there is definitely a problem.
08.05.2020 14:09 # 6
hasimayaz
For ABS, it is necessary to have the car connected to the computer. The reader can also be a sensor, hydraulic fluid too ..
& nbsp;
Central lock and immo are different issues. Immo surely there .. Could you lighten the subject a bit for the central lock ?? switch button not working? or the central lock button on the console?
& nbsp;
