ABS does not work after 5008 Tire Change
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 5008
08.05.2020 19:18 # 1
toprak_55
Hello friends.
I joined you with 2011 Model 5008 Premium Pack.
In February, I changed the tires of my vehicle, which I purchased should have changed due to use. After a few weeks when I went to service, he said that ABS and ESP are not working and that ABS light is on. Could the abs not work after tire change (4 tires). The service says that the ABS light is on, but I have been driving this car for 3 months. I have not seen the ABS light once. I didn't test ABS either. Anybody have the idea of what I can do.
It is written in the forums that there may be errors in the ABS sensors, I think these are perceiving the speed. Since the cruise control works in my vehicle, can it be said that there are no errors in these aBS sensors?
He also said that the battery had a problem with the battery, and that the problems could be related to the battery. What problem could it have on the vehicle battery if you worked every time I turned the ignition?
Please feel free to write your ideas. Thanks.
toprak_55 2015-06-03 14:34:10
08.05.2020 19:18 # 2
welcome my fellow abs problem can be caused by sensors. If the sudden braking structure is not activated on an empty road, the front wheels will be locked. so you can easily understand. have the battery measured elsewhere, if it is caused by the battery, it already exits the voltage values. If the battery does not produce enough voltage, it can cause problems in digital systems such as abs. Get well soon.
08.05.2020 19:18 # 3
berk2309
they suspended the vehicle, if they started the vehicle so that the abs lights up, the wheels freeze and cause an error in the abs, too, since it could not detect the speed when the car was suspended, I would either insert the pole of the battery and suspend it to the computer.
08.05.2020 19:18 # 4
toprak_55
Let me clarify the issue, I wrote wrong because
I don't know if ABS works before changing tires. Because no light is on and I did not brake suddenly. Just when I said the service, it came to my mind that I changed tires
08.05.2020 19:18 # 5
berk2309
If you are wet or gravel on the empty road, the brakes are suddenly braking and the experiment is running if there is no aquaplaning on the pedal.
08.05.2020 19:18 # 6
toprak_55
I will try it in a suitable place. As of today, I bought an ELM327 diagnostic tool. Also, I will check myself where my brother will break down. Does anyone know which application is using the ELM327 device in peugeot.
08.05.2020 19:18 # 7
riderzist
[QUOTE = soil_55] I'll try it in a suitable place. As of today, I bought an ELM327 diagnostic tool. Also, I will check myself where my brother will break down. Does anyone know which application is using the ELM327 device in peugeot.
You can use torque or scanmaster on android phone, but if there is a problem in abs sensors, it will be lit even if you delete it. Did the tire pressure sensors change location, can I do it? those who need to put the resulting agent in the same place or damaged the abs sensor.
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-yedek-parca-otomobil-arazi-araci-abs-sensoru-on-307-308-rcz-c4-3008-5008- C4-original-4545.k3-187604283 / detail
something like that.
the socket might have come out.
riderzist 2015-06-06 04:29:22
08.05.2020 19:18 # 8
toprak_55
Tires changed one by one, I know that the dismounted horse was stuck on the ground again. Find an opportunity to lift it in the fiber, I will understand what is what. I will check and clean the abs sensors.
Does anyone know what ABS sensors are called in this torque or scanmaster program.
