ABS DOES NOT WORK
08.05.2020 15:13 # 1
ismail ozdemir
friends slm 5-10 days ago abs heat burned and the abs is not working right now the vehicle brakes normally, sometimes if I brake less, the genius gets locked and starts to slip.
08.05.2020 15:13 # 2
106_arts
THE SAME OF THE DISK AND THE PADS ARE THE SAME IN THE BAN
08.05.2020 15:13 # 3
ismail ozdemir
Yes, I talked to the master today, let's look at the pads and sensors. your problem is halloum?
08.05.2020 15:13 # 4
Serhun
In general, the sensors get dirty and when it is cleaned, the problem is solved. Good luck with
08.05.2020 15:13 # 5
There may be a problem with abs sensors, cables or sockets on 4 wheels. This is the most undesirable and rare problem that can also occur in the abs center.
08.05.2020 15:13 # 6
ismail ozdemir
I hope it is not my center anyway as far as I understand it is not a nice situation
08.05.2020 15:13 # 7
[QUOTE = beyazzzzz] I hope it is not my center anyway as far as I understand it is not a nice situation [/ QUOTE]
we can say at the abs pump. The pump operates according to the information coming from 4 wheels and the brake pressure is applied to the required wheel as a blow ... this is how the system works.
08.05.2020 15:13 # 8
ismail ozdemir
I hope there was no problem after this error, I did a brake the moment passed after the error, but the abs didn't work, but the brake was like that, and the car started to slip. In the last 10 days, the last lamp went out, the absde worked, but this lasted, then went again Ouch
08.05.2020 15:13 # 9
okay :)) abs does not work as long as abs heat is on. then you have a normal brake ... if you connect pp2000 to the computer, i press it very hard i believe it will be resolved
but I guess there might be a problem with the abs cables or the wheel sensor. Maybe it can be corrected when cleaning :))))))))
08.05.2020 15:13 # 10
ismail ozdemir
thank you I will handle it as soon as possible. I have a problem, it is not exactly a problem, but if you have information, I would like to consult you.
This tripodic gear lever is locked in sudden passages and suddenly when I get d from the gears, the d position is locked in the middle of the position, the screen writes me on the screen. though it happened 3 times in 1 year, but it wouldn't lead to anything bigger while using pressure three times :)
08.05.2020 15:13 # 11
Do you have a separate subject for the transmission fault? :) You can continue it from there ...
08.05.2020 15:13 # 12
ismail ozdemir
OK thank you
