ABS and BRAKE DISC
08.05.2020 14:09 # 1
friends with my car, sometimes going to work in the mornings, by setting off the first heat, I take the main road by heating the downhill engine. do you have a problem & nbsp;
08.05.2020 14:09 # 2
tugrabozan
Dear polatkaptan & nbsp; I don't think that the activation of the abs will be related to the end of the disc, but the sensor of the abs receives a signal from the gear-like place on the head of the axle, but if the disc is scratched or rough, it can snap suddenly during braking.
08.05.2020 14:09 # 3
the master looked at the service said the disc thinned
08.05.2020 14:09 # 4
brake shifter changed between you and how many km
08.05.2020 14:09 # 5
tugrabozan
If you can find a caliper, measure the zero on the particle with your own disc.
08.05.2020 14:09 # 6
best of all this shape seems & nbsp;
08.05.2020 14:09 # 7
H-a-d-i
Although it is not a very expensive piece, the task it undertakes is quite a lot. that brake will need several times already in life. If it doesn't work then, I'm doing ABS!
supplier industry, I heard that the pair was 120 TL. the lathe also wants at least 30-40 TL. do you think it is worth
08.05.2020 14:09 # 8
Of course it's not worth my money
08.05.2020 14:09 # 9
Aytac
First of all, the disc in the car is caliper compared to the new one.
08.05.2020 14:09 # 10
Onur
Buying and installing zero discs makes the most sense, even the original brake wouldn't be this joke
