ABS AND AİRBAAG FAULT HTA
08.05.2020 17:03 # 1
ERTURK
Hello,
2004 I own 307 sw vehicles. My vehicle started giving ABS and Airbag Fault errors 2 days ago. Suddenly, error messages and Stop warning flash on the screen then suddenly the steering becomes hard. I took it to the private service, they tied it to the machine, it was not important, they said there was no problem due to cable contact, but I had the same problem today. I would be glad if you share your information and comments about the problem and the ways of solution. Regards ...
08.05.2020 17:03 # 2
fexzi
may be deformed in the airbag cable on the seat, have the right and left seat airbag cables checked.
08.05.2020 17:03 # 3
mesutay20
I'm having the same problem, the airbag signal is on. warns the news on the road computer. I wonder how we're going to do those nodes in the armpit & Nbsp;
08.05.2020 17:03 # 4
Your problem may also be alternator or battery source. If you want, have a look at them.
08.05.2020 17:03 # 5
ERTURK
Hello again, I went to the service today about the problem I mentioned above. They said there was a problem with the generation and distribution of electricity due to a problem with the vehicle's charging dynamo. Due to the problem in the dynamo, we also replaced it, which was finished on the battery. They also renewed the hydraulic oil for the steering. I hope it won't repeat anymore. In the meantime, friends who have this problem should have it done without delay. Because the distress affects all of the vehicle's electrical parts, it can cause serious problems in the brain. In such a case, the expense will be much higher. The money I spend for my transactions is around 500 TL. I don't know if I gave more or less, but believe me, I just don't want to use my car without any problems. Love to everyone ..
Battery has changed
Charger has been repaired (not changed) & nbsp;
Hydraulic oil has changed
< div> Labor
500 Tl & nbsp;
08.05.2020 17:03 # 6
durucuk
how do you repair & nbsp;
& nbsp;
