ABS
08.05.2020 17:56 # 1
phoenix.1905
I changed the clutch set of my friends (306) about 1 month ago. During this time, I realized that ABS does not engage in sudden brakes. If I used sudden braking at 50 km in the past, I would get a reaction from the brake pedal. There is no such thing now. Also, the ABS malfunction light does not light up.
I am waiting for your comments!
08.05.2020 17:56 # 2
phoenix.1905
date ...
08.05.2020 17:56 # 3
Serkan
If the tires do not slip when you brake, there is no problem.
08.05.2020 17:56 # 4
phoenix.1905
Tires do not slip, but neither science would have felt that reaction on the brake pedal beforehand. Well, if the tires do not slip, can we say that the abs is engaged?
08.05.2020 17:56 # 5
Serkan
Hodja ABS tires come into play when they are about to slip and prevent them from slipping. If the tires are not slipping, it means that ABS has not been braked as hard as it should be. If the tires slip, it means that ABS is not engaged. Apply a hard brake in a safe place with ABS engaging, no problem if ABS engages, there is a problem if the tires slip. If the ABS light is not on, there is no problem, but rest assured.
08.05.2020 17:56 # 6
phoenix.1905
Eywallah brother try and see you see ..
