ABS
08.05.2020 17:05 # 1
rhcpeppers
Hello friends. This break brake scares me. I have doubts whether the abs is activated or not. As I was passing through the lights recently, the vehicle in front stopped to explode, but I was in vain. It makes trembling. Clutch set had changed 1 2 months ago. Could it have anything to do with it? Or am I noticing my abs when it comes in?
08.05.2020 17:05 # 2
impact
ABS is not a problem either, but it seems like I do not have much benefit in sudden brakes or psychological .. & nbsp;
08.05.2020 17:05 # 3
xpyhre
It throws it back and vibrates and the abs works.
08.05.2020 17:05 # 4
rhcpeppers
yes it trembles but shouldn't it stop pat? ;) The passing lights will turn red and I looked at the front transporter. When I said the 2nd gear, the vehicle stopped suddenly, but we went to no avail. Fortunately, there was nothing other than 1 2 tracks. & Nbsp;
08.05.2020 17:05 # 5
fTh206
[QUOTE = rhcpeppers] is shaking yes but shouldn't it stop pat? ;) The passing lights will turn red and I looked at the front transporter. 1 When I said the 2nd gear, the vehicle stopped suddenly, but we did not succeed, we did not have anything other than 1 2 track. stop late
08.05.2020 17:05 # 6
simirnoffredbull
Unfortunately, you know the abs. abs is for brakes without locking the steering wheel in sudden situations, to prevent accident.
08.05.2020 17:05 # 7
rhcpeppers
it is true thanks for the information friends
08.05.2020 17:06 # 8
Serkan
ABS has almost no effect on stopping distance, its main task is to prevent the wheels from locking during braking and maneuvering the vehicle, so you can both brake and run left, but if there is no abs, maneuver as much as you want after the vehicle starts to slip.
08.05.2020 17:06 # 9
rhcpeppers
thank you
08.05.2020 17:06 # 10
aslanparcasi
you think about the topic of tires, I think the abs also comes into play early because the tire hardens or there are no teeth left
08.05.2020 17:06 # 11
jiyanxese
If tremor has happened, then the abs is activated :)
