abrupt stop engine and not running without cooling
08.05.2020 21:15 # 1
Dogukan_3002
Hi friends. There is such a problem for 3 days. so it was new. When it is cold in the morning, I run normally and set off. there is not the slightest problem. but when the engine has reached its operating temperature, it stops suddenly while continuing to go on the road. I am starting again, running, going 1 km, stopping again. This time it goes 500 meters when you start again and when it stops it doesn't get any more. then it doesn't work with 1-2 hours wait. I expect it to be morning Confused Has anyone had the same problem? my guess is electrical. either there is a malfunction in the brain or like sensors Dogukan_3002 2019-06-22 11:07:22
08.05.2020 21:15 # 2
talip206
Sir, I would say the starter motor if it wasn't running after you stop it, but when your car warms up, if it stops on the road and doesn't work, it runs 99% brain failure. The same happened to me. When cold, the car started to stop when it was moving when the car got hot. The possibility of the brain was said, but we left it last because it was expensive. I spent two brain money to make money. I think go to the cerebellum directly and make a malfunction. If the brain says they're strong, you turn to something else. It goes to 100 lira for maximum detection. Otherwise, you start from the crank sensor. When you say spark plug coil speed sensor gasoline pump lpg elements or something, you can't get out of it.
Let me give some advice. When it is stopping and not working while it is hot, wet a cloth and put it on the brain. Wait a moment and try to run like that. If it works, it means trouble when the brain gets hot.
08.05.2020 21:15 # 3
Dogukan_3002
[QUOTE = talip206] My teacher would say the starter motor would not start when you stopped after stopping, but 99 percent brain failure if your car warms up and stops working on the road when it cools down. The same happened to me. When cold, the car started to stop when it was moving when the car got hot. The possibility of the brain was said, but we left it last because it was expensive. I spent two brain money to make money. I think go to the cerebellum directly and make a malfunction. If the brain says they're strong, you turn to something else. It goes to 100 lira for maximum detection. Otherwise, you start from the crank sensor. When you say spark plug coil speed sensor gasoline pump lpg elements or something, you can't get out of it.
What happened in the bidet started in 3 days. very bored. I'll put a towel in the brain in wet water and try it. because it works without any problems when it cools down. There is not the slightest problem in his traction on his way. I think it should be from the brain Clap let me write a try again
08.05.2020 21:15 # 4
ismailkaya
Does the vehicle work after stopping all the functions, for example if the lamps are working and the pine on / off buttons are working actively; Check the speed sensor The cable may be caused by the speed sensor in case there is a problem with the socket.
08.05.2020 21:15 # 5
Dogukan_3002
[QUOTE = ismailkaya] After the vehicle stops, does all the functions work, for example, if the lamps are working and the pine on / off buttons are working actively; Check speed sensor The cable may be caused by the speed sensor in case there is a problem with the socket. [/ QUOTE]
yes everything works except the engine LOL but I don't know the location of the speed sensor. Is it necessary to remove the right front wheel and look from there?
Dogukan_3002 2019-06-23 09:05:09
08.05.2020 21:15 # 6
My brother, who has a vehicle diesel, has a similar problem with 206 1.4 hdi. because the vehicle stopped touching the cabos while it was running.
08.05.2020 21:15 # 7
Dogukan_3002
[QUOTE = sonerkyl] car diesel bro my brother has a similar problem 206 1.4 hdi came to our head, complete ecu installation was renewed and the problem disappeared from there. because the vehicle stopped touching the cabos while it was running. [/ QUOTE]
petrol. At 150 thousand km. There is no overheating and normal operation. but there is also something like this I have been using the backup key for about 2 months since the keys of the master key have been broken. could he have started doing this because of this? Now I am back to the real key. If I use it like this for a while even though its keys are broken, will it pass by itself? In such a problem, we thought of the first brain ecu or something, but I suspect the immobilizer system.
Dogukan_3002 2019-06-24 11:01:22
08.05.2020 21:15 # 8
talip206
It may also be an immobilizer, but then it gives the brain an immo error. As I wrote above, I tried all of them. Trial with spare key, crank sensor, coil, spark plug, battery, speed sensor, fan rollers, overheat sensor. We came to the brain last but both brains are gone.
But you can try without expense without hurrying, for example try with another key, make observations. If you can find a friend or relative, change the batteries and try. But don't take parts and spend money. Touch the brain when it is malfunctioning. If it's hot, try putting the wet cloth (not too juicy) over the brain.
08.05.2020 21:15 # 9
Dogukan_3002
friends problem immoblizer appeared. I also mentioned in my previous message. I used it with the backup key for a long time. returned to normal after returning to his main key and using it for 2-3 days Smile no longer stops Smile that is, do not use the spare key except in very essential cases.
edit: I used 350 km in 2 days in the city. the smallest problem
Dogukan_3002 2019-06-28 13:41:58
