About zenon.
08.05.2020 20:17 # 1
Peugeot35
friends, I turned the work lights on the left side, the xenon headlight on the left started to blink and when I got home, the completely extinguished battery was burning like a lamp.
I don't know much about xenon.
Now my bulb burst or something else broke down.
Does anyone know what the prices are about if the bulb is broken?
what are your suggestions?
08.05.2020 20:17 # 2
I think my spoiled teacher will not give any light if the bulb explodes. Depending on the ballast place, it can be between 30-50 TL.
08.05.2020 20:17 # 3
xdesign_206
Most likely, the ballast is broken, you will see if it is the guarantee that you can remove the ballast on the other side and put it there.
08.05.2020 20:17 # 4
pusutr
So did I. Ballast life for you. I bought a new zenon set and used its ballast. The set itself is already 70 80 rubles. I didn't get to pay 50 TL for the ballast.
However, it is very difficult to set these zones. Either the light is scattered, above or below. A kind of fastening scheme. Does anyone know the trick of this :)
08.05.2020 20:17 # 5
Peugeot35
Guys, today I disassembled the broken headlight bulb and put it in place of the other headlight. There is no click on the lamp. Like the past bulb, which means that the headlight bulb is a lie. I looked at the prices 36 tl one by one, it was not appropriate to change the color difference, but somewhere I found the pair to 34 tl. Peugeot35 2017-04-05 20:12:03
