about wurth injector cleaner
08.05.2020 19:08 # 1
berkayakulker
Friends I ordered online, the product will arrive in 1-2 days. If you have a friend who has used it before, please don't forget your comments ...
The purpose in my use is that the engine works very loudly nowadays. There is a 2 times difference with the old voice, diesel sound is ok but it started working like a tractor ...
08.05.2020 19:08 # 2
baybaba
If your vehicle is high km and you have never used similar products before and in your vehicle
If there is no problem, I do not recommend using it, it is said that the intensive vehicles that are
During the sudden cleaning process of some institutions, some of these institutions nipple
it is said to be clogged and cause much voiding, leading to voiding, low
km use is not a problem, after high km troubles in my vehicle 135 thousand diesel
I do not intend to use,
08.05.2020 19:08 # 3
Alicilik
Injector cleaner and carbon clean are very different.
When the injector cleaner is placed in the full tank, it cleans the deposits in the injector along with the fuel.
Wurth quality, I recommend you use it before maintenance. After finishing a tank fuel and entering the service, you will see a good difference if you open 1 tank breaker and injector afterwards,
08.05.2020 19:08 # 4
berkayakulker
My vehicle has 200,000 more maintenance time ... almost 7000 :) How does it make a difference to use a full tank and a less full tank?
