About Visa
08.05.2020 18:10 # 1
Guys, I have an inspection of my vehicle next week. I have a few questions. There is a Junyan headlight and a xenon bulb. I will replace the bulbs with normals, but will LEDs cause problems in parks? More precisely, let me ask, is there anybody who came with Junyan headlight? No original headlights. I would appreciate if you have an idea
08.05.2020 18:10 # 2
kursat3006
Disassemble XENONs, I know that others will go through the slightest defect.
08.05.2020 18:10 # 3
kuscu38
My friend, the type of the headlights, the appearance is not important, the worst case is that the headlight adjustment is not suitable, it passes slightly defective. But Xenon bulbs remain severely flawed.
Signals burning in the form of American parks and parks do not pass, except for the original yellow color ...
Let me tell the word that is written for your friend's car, "inappropriate burning" for the parks :)
08.05.2020 18:10 # 4
[QUOTE = 307bursa] The same thing is present in me, I just removed the xenon bulbs and passed, you don't need to do anything else [/ QUOTE]
Is it difficult to disassemble these bulbs and which bulb type is the original? Was it led in the parks? I asked a lot of questions but :)
08.05.2020 18:10 # 5
barishrocker
There is a slight flaw in the different parks. It is not subject to inspection. Last month, I passed with white parks slightly flawed. But xenos do not pass.
08.05.2020 18:10 # 6
herry
my friends have peeled though, but let me know for sure. Good luck with.
08.05.2020 18:10 # 7
I will remove the xenos, of course, but it was the parks I was curious about. Well, do LEDs cause problems in the stops? :)
08.05.2020 18:10 # 8
murat328
pilgrim I have it in my car, my parks LED blue light defect is passing, only zones are yellow yellow plug is not a problem.
08.05.2020 18:10 # 9
volkanC2
my parks (led) and angel rings light up white short high beams yellow normal bulb, parking lamp color does not comply with the regulation on inspection - it is a slight defect.
08.05.2020 18:10 # 10
barishrocker
The middle stops, that is, pass even if the tailgate does not burn. For additional information :) The expression of the slight defect of the parks, as the volcano says ..
08.05.2020 18:10 # 11
samet206
xenon heavy defect, the color changes on the headlight pass as a slight defect, but now it changes only in some times, how I say, I witnessed recently, for example, one man led a strip led instead of the back plate lighting, they said it came to the man as if they were so bright :)
08.05.2020 18:10 # 12
Thank you very much, guys, you helped a lot
