About Triptonic Gear
08.05.2020 20:25 # 1
307XS307
Hello friends. My 307 xs automatic transmission is also available in manual use. I bought the pejo for the first time and I have no knowledge of the automatic use of the automatic gear, so I always use it in the automatic position, in D position.
My question to you is: if I want to use it manually, for example, let's say I am going in 3rd gear. I have to stop at the red light. Do I need to slow down by shifting to 2 and 1, or does it just slow down and slow down by applying the brakes? I would be glad if you inform about this issue. I wanted to ask you first because I have never tried. or let's say, in normal manual vehicles, let's say that when you go in 4 th gear, when you suddenly brake, you do not press the drain, the car will stop. This is the case in the manuals of these automated vehicles, that is, when driving in the 4th gear, the car stops in the sudden brake because there is no drainage because?
08.05.2020 20:25 # 2
selcuk3641
When you apply it manually, when you press the brake, the gear shifts itself, but no matter how much you load on the throttle, the gear does not increase.
08.05.2020 20:25 # 3
just like our friend says, he drops the braking on his own.
08.05.2020 20:25 # 4
307XS307
Thanks a lot for your answers, friends. Thanks to you, I used the tool for the first time today.
08.05.2020 20:25 # 5
selcuk3641
Get your hands done well. It works very well for overtaking. The manual works well if there is a sport mode.
