About the warning indicator
01.01.2023 17:43 # 1
sahinsenturk
Hello friends
What does the following warning mean? It lights up occasionally and then turns off by itself. Vehicle 1999 model 206
01.01.2023 22:35 # 2
talip206
The photo does not open.
02.01.2023 12:20 # 3
sahinsenturk
I can't add :( can you help me how to add?
03.01.2023 19:05 # 4
talip206
You can upload it to the quick picture site or similar sites and paste the link here.
04.01.2023 22:55 # 5
sahinsenturk
I'm uploading as follows, I hope it looks
05.01.2023 10:28 # 6
Berkay Erdinc
Hello
The fault lamp is on, have it connected to the device as soon as possible and find out why it is on and the solution.
05.01.2023 15:34 # 7
sahinsenturk
The fault lamp is yes, but we could not find it and it does not come on when we plug it into the computer because it does not light constantly.
05.01.2023 15:51 # 8
Berkay Erdinc
Şahin Bey does not burn for a single reason. It can cover the ignition system in general, the fuel system in general, the exhaust system in general, the air intake system and the entire exhaust system. Therefore, no one can say for sure if it is from this part, but can make an estimate. No one wants to go under this ball because it will burn pockets.
I can suggest the following as a solution
The error record that occurred in the original device should not be deleted.
You can take it
Finally, you can get an obd2 device. In this way, as soon as the malfunction light comes on, you can connect to the ecu from the phone and see the malfunction.
05.01.2023 15:57 # 9
sahinsenturk
Thank you very much
