About the turbo heat shield
08.05.2020 18:35 # 1
netweb
friends of 307 turbo heat shield and manifold heat shield old bought the car I bought 2nd hand I used this tool for 1 year should I buy and install those parts definitely NetWeb 2014-05-29 23:48:44
08.05.2020 18:35 # 2
madblueblacksea
When I bought it in my car, it was not bought, I bought it, but I can not say that it must be definite. It protects the parts around it (radiator, charge dynamo) from the heat emitted by the catalyst and exhaust manifold, providing a clean appearance inside the engine. Of course, the price exceeds 150 TL.
08.05.2020 18:35 # 3
renk1234
I used it for 4 years without a shield, it did not cause any problems: D
08.05.2020 18:35 # 4
GokhaN
I recommend you wear it. It provides the minimum possible reflection of the heat that may occur on other parts. God bless fire, etc. allows you to take action against events.
08.05.2020 18:35 # 5
serkomser
Is there a turbo in the 307s? 2004 Is there a model 307 1.6 XR in this?
08.05.2020 18:35 # 6
badcombatant
I think it's definitely best to appreciate it. You will be comfortable for the most important of all, you can prevent the problems that may occur.
08.05.2020 18:35 # 7
oguzhan29
our 206 das were a little deformed, and I will change soon.
08.05.2020 18:35 # 8
serkomser
What if I asked a question?
08.05.2020 18:35 # 9
oguzhan29
my brother hdi turbo diesel engines brother.
08.05.2020 18:35 # 10
alman10
If your heat shields are deformed and dislodged, it is good to change your friends, at least the part that faces the radiator. Because it can give the heat that occurs in the exhaust to the radiator and this can make it difficult for the engine water to cool down especially in the summer months. The other aspect of the work is that the inside of the catalytic converter sometimes rotates and exhaust gases that cannot get out of the exhaust excessively raise the exhaust manifold temperature. In such cases, it can also physically damage other parts.
It is related to issues such as smoke escaping from the heat shield passing in some places in the forum.
