About the Timing Set (tension ball)
08.05.2020 18:33 # 1
timess
I have a question for you now
I have a partner 1.9 vehicle 49000 km I changed the timing belt for 5 years, I tried to get the original parts I bought but I didn't like the sound of the parts. the parts I put on should go 30 000. I would replace them completely. Did I need to replace these 30 thousand or did I need to change the timing?
By the way, my car is out of 2007 8 months
08.05.2020 18:33 # 2
suppor
There is a part that I call the tension wedge. There is a sound from it. I think it has to change.
08.05.2020 18:33 # 3
ahmed206
Have a message. I will add information here at the appropriate time.
08.05.2020 18:33 # 4
timess
My question was actually, would it be a problem if I put on the old tension ball? Now at 49000.
I bought the old pieces, just in case.
there is almost no scratch on the timing belt I bought it too
old parts seem better than new ones.
There is very little sound right now. According to the old voice, if the room repairman loosened a little, that sound goes away, but he cuts the sound over time.
08.05.2020 18:33 # 5
Serkan
I do not think that the timing life will be different for 10 years or 180.000 km, 1.9 diesels in my HDI engines.
08.05.2020 18:33 # 6
timess
should http://www.uzmantv.com/triger-kayisi-ne-kadar-surede-yenilen
if I catch this guy ... :)
I believed the word of this man, I changed it. It was a pity, my money was wasted too
By the way, my vehicle is 1,9 diesel in 2007
08.05.2020 18:33 # 7
Serkan
Sir vary from vehicle to vehicle, benzinili in 5 years, for example, the Peugeot Turkey's message with the information at your car from the official page they give information within 2 days.
There is information for some vehicles in the link below.
08.05.2020 18:33 # 8
sabahattin
I also have a 2011 peuget partner, I don't know if tiriger is on the belt, there is too much noise.
08.05.2020 18:33 # 9
ahmed206
Of course. If it has not changed by this time, you must change it.
Get quotes from the widget and internet, use whichever is appropriate. The production dates of the belts are important. Do not be older than 2015.
08.05.2020 18:33 # 10
[QUOTE = sabahattin] I also have a 2011 peuget partner, I don't know if tiriger kayişindan I have a lot of noise, I wonder how much the prices of the bidet car 126 thousand of these parts have to be changed before I wonder if I had a peuget before, I am a little novice can you help [[QUOTE]
It is not a situation related to peugeot, this is not a situation related to peugeot. it is actually longer in booklets, but it can cause you to have a complete engine for 300-500 rubles. If the original timing set changes around 160 tl with v-belt, it will average 200-250 tl of work on average around 180-200 tl. it will be cheaper if you only find the v-belt bearing.
