About the Temperature Sensor (Solved)
08.05.2020 17:16 # 1
Burak
my car is not from you anymore, but with the support given by serkan brother, I am convincing me that I am one of you. I suspect the fever sender is moving up according to your head because it is the reason why do you think the defect of the customer will cause such problems?
mekanuaes 2013-01-09 20:21:02
08.05.2020 17:16 # 2
Serkan
Burak came to my mind, let's not have a fan lamp that you call the heat lamp, there is no peugeot, but when the fan was activated on my broadway, the light was on the indicator, it turned off when the fan was turned off.
08.05.2020 17:16 # 3
Burak
It drops to 60, but the temperature becomes the first to start the cold car in air.
08.05.2020 17:16 # 4
Serkan
I don't think it's the problem, after all, it doesn't always work at 60 degrees, right?
08.05.2020 17:16 # 5
Burak
It drops to 60, then the fans turn off, it becomes the normal level again, after a while, the same process
08.05.2020 17:16 # 6
Serkan
I think the answer to this question is in this APP ...
Thermostat Faults:
1. If the thermostat cannot be opened at all:
The heated engine water cannot be sent to the radiator because the thermostat is not opened and the temperature of the vehicle increases.
2. If the thermostat stays open all the time:
The engine water is constantly recirculated and the temperature may not rise at all. I say it may not rise because it depends on the air temperature and my driving situation. In other words, if the environment is very cold, it does not rise at all, if the ambient temperature is high, it can reach 70 degrees but it cannot rise any more.
3. If the thermostat opens to the required degree but does not close after opening (the most common thermostat malfunction)
The temperature of the vehicle is up to 90 degrees since there is no problem in the degree of opening the thermostat. It comes out normally, but since the thermostat is always open, the temperature may fall even below 70 degrees Celsius compared to the environment.
08.05.2020 17:16 # 7
Burak
3. It looks like malfunction. My problem remains open.
08.05.2020 17:16 # 8
Burak
Is there nobody else to answer, or that exclusion is so my car is not a pug :(
08.05.2020 17:16 # 9
Burak
The problem is solved. The temperature lamp due to lack of water is on and the thermostat is defective and the temperature of the vehicle decreases as it reaches the normal level. 01:12:12
08.05.2020 17:16 # 10
Burak
The problem in the temperature sensor was not solved by the thermostat.
