About the Peugeot 406 wet floor |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406 | |
| 27.03.2022 17:07 | # 1 |
The floor carpet wet heater core has been changed since Pejo 406ti bought it I wanted to ask if it gets water from anywhere else Thanks in advance. div> There is a video about how much water there is but I couldn't put it here
| 28.03.2022 18:09 | # 2 |
sonerkyl |
Is there a sunroof, sir, in the vehicle. it could also be caused by the door trims.
| 28.03.2022 18:11 | # 3 |
no sunroof
| 28.03.2022 18:19 | # 4 |
sonerkyl |
Then, my teacher, there are two options left, either from the door or from the front flank.
| 22.05.2022 23:55 | # 5 |
I recently supported the windshield from 2 sides and the top with black gasket silicone. The windshield and even the rear window are free of silicone. There was a lot of water inlet. there is a heating radiator there. Two aluminum pipes are inserted, and they are fixed in place with a metal plate with a single screw. There are 2 o-rings there. Water is leaking from them too, replace it.
| 25.07.2022 12:53 | # 6 |
IF THE FLOOR CARPET IS WET, THERE ARE 2 POSSIBILITIES. 1. There is a heater core right behind the console where the heater-air conditioning buttons are located. There are 2 orlings that attach the pipes there to the honeycomb. They are rotting. it leaks in weight. 2. The water channel of the doors is closed. As the vehicle is washed or it rains, the water accumulating inside the door leaks inside. Now let me tell you a method. If you have antifreeze in your car... touch the floor carpet with your finger and touch the water to your tongue. if it is a sugary and sticky liquid, it is the orlings of the heater core. if it is normal water, it is the lath, gasket and water channels.
