About the Peugeot 206 shaking problem
08.05.2020 21:28 # 1
sevki18
Hello, good forums,
First, 3 months ago, I joined the 2005 model pejo 206. I'm having a few problems with the vehicle. I joined the forum to get support from experienced people in the forum. Vehicle lpg li bud
In low gears, especially in 1st and 2nd gear, the car shakes violently when I take my foot off the gas. The throat butterfly has just been cleaned. The problem continues. The other problem is the car's 4th and 5th gear whilst your foot accelerates while the engine accelerates. Thanks in advance
08.05.2020 21:28 # 2
MDKBKR
I think the whistling sound indicates a manifold leak. For shaking, I think the spark plug may be related to the coil if it is making it more pronounced in LPG.
08.05.2020 21:28 # 3
ismailkaya
The engine type of the vehicle is 1,4 16V 90 hp. or 1.4 8v. Are you the one?
08.05.2020 21:28 # 4
sevki18
hello 1.4 8v my vehicle is very annoying, especially in traffic stop and get shaking. I want to solve it, I wanted to consult you.
08.05.2020 21:28 # 5
ismailkaya
shaking from the clutch plate. If the whistling sound is cut off to the clutch pressure, it may be from the clutch ball. It may be from the alternator ball. I don't think it will be from buckles, but one possibility should be checked looking at the engine and transmission ears. advance sibop sente settings should be checked, look at a good master, do you experience fluctuating idle in lpg
08.05.2020 21:28 # 6
MDKBKR
[QUOTE = referral18] hello 1.4 8v my car is very annoying, especially when the traffic is shaking when you stop. I want to solve it and wanted to consult you. [/ QUOTE]
Your vehicle is the same as my vehicle. I had the same problem. The lpg master found the cause of the problem. The tip of one of my spark plug tires was broken. I solved the problem with 1 set of new spark plug tires and 1 set of new spark plugs. Look at the spark plug and coil.
08.05.2020 21:28 # 7
sevki18
Hello my teacher
Idle fluctuation, throat butterfly cleared did not improve again
08.05.2020 21:28 # 8
Ekaya76
I also bought the new semi-automatic 2004 model 206. There is no gas in the vehicle, it only works with gasoline. When I reach 70 km and above, the vehicle starts shaking in me. Shaking stops when you press the gas and increase the speed. The same thing happens when I use the tool manually and this shaking generally takes 70-80 km. Where could the problem be?
Another question is that my vehicle shifts at 4000 rpm. I always used my vehicles at 3000 rpm. Can this shift cycle be changed?
08.05.2020 21:28 # 9
Bursa16
I just came from the mechanic, I was going to be happy, thanks, master. What is the master, but I couldn't count. The malfunction was in one of the injectors. First I found out which injector was faulty, and then I am happy.
28.12.2023 18:00 # 10
Gurur206
Sir, did you solve the problem?
