About the oil change (206)
08.05.2020 20:38 # 1
RP393
Content was deleted while friends are editing on mobile.
It has been 11.500 km and 8 months since my 206 1.6 xs car did not change oil. The oil is still yellow and looks good. (shell 5/40)
Do you think I should change it? RP393 2017-11-13 17:45:22
08.05.2020 20:38 # 2
samet206
There is no such thing as the oil will last its lifetime until the end or it will darken and end. The producers or services have different maintenance intervals and the lifetimes they set for the oil. He says that it should change in 15 thousand. It changes according to the situation, but this subject depends on the user request and usage. I change it for 10w40 every year or 10 thousand km.
samet206 2017-11-13 19:32:03
08.05.2020 20:38 # 3
RP393
I use the vehicle to go and come to gebze-izmir once a month. Km is over, but it is not a vehicle used for contempt. I say that I do not charge because the oil stops as it was on the first day. Of course, I don't know what the filter is. If it goes up to 15 thousand.
08.05.2020 20:38 # 4
samet206
One of the ways to extend the life of the engine is to make the oil change in a timely manner. I recommend change at 10 thousand km, but they are stretching up to 15 thousand km for 5w40 oils, so the decision is completely up to you. 5w40 users will make better comments.
08.05.2020 20:38 # 5
yigit_dark
I find it convenient to change it at 7500 km. In the last change, I could not find an opportunity and the room corresponded to 8100km. Some says early, some says appropriate. I think it depends on the importance you give to the vehicle. Some never change.
08.05.2020 20:38 # 6
Karacocuk24
Of course, if there is a possibility, it is like 10 thousand ideal, but if you are doing most of the km on the long road, change it after 1 year. There will be no trouble unless you exceed 15 thousand in 1 year.
08.05.2020 20:38 # 7
maximusti
I do not use contempt at all, but I change it at 9000 9500 km.
