About the new Peugeot I bought
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 20:52 # 1
hanzade34
Hello Friends I Just Joined You, My name is Burak Istanbul
I bought a Peugeot 1999 406 2.0 SV vehicle, I got an expertise in 295 thousand, only the hood different engine condition 90% However, the tachometer rises in the vehicle, but the speed does not increase, there is an unnecessary shout. The overheat hangs between 90-100 in heavy traffic, and when it is opened, it drops to 80-90 and the airbags are not opened in the original state, but if I think its sensor is related, its lamp is on. What if I can get your comments and ideas.
Good Forums
08.05.2020 20:52 # 2
hanzade34
And in addition, the idling rises by itself. Fuel is increasing for this reason. The idle engine side industry said they ordered the original, but it has not come yet.
08.05.2020 20:52 # 3
talip206
Best wishes. It is likely that the speed will not increase and the speed will be related to the press lining.
Overheating is normal.
There may be many reasons for idle ripple. Start by cleaning the throat butterfly. Have any air leaks checked.
You need to connect it to the computer for Airbag and see which one gives the error. If there is a curtain airbag, check the sockets under the driver's seat. Usually they are relaxed.
08.05.2020 20:52 # 4
dou
good luck your new vehicle Smile
By the way, for the first time, I am using the peugeot 206, the temperature on the highway was 91 92 and it was 110 directly. I did the same again, I said I would open the hood again, it came to 91 degrees, then I proceeded with a 70 80 km face, I immediately changed the thermostat, but I haven't tried it on the highway, what would be the problem?
08.05.2020 20:52 # 5
hanzade34
Thank you for your opinion :) I did not think of the pressure pad and at the same time, I put it in 1st gear while getting up, I remove the clutch and move forward 2 3 seconds later, when the clutch is in the middle, that is when it is about to quit, it sounds like the car is stumbling. In second gear, it is shaking back and forth as soon as it reaches 2000 cycles without stepping on the gas. Could it not be due to this reason
08.05.2020 20:52 # 6
hanzade34
Also, there is a lpg in the vehicle, can the problem of fluctuation fluctuate from it? sometimes he does it extremely, sometimes very rarely.
There is also an airbag under the curtain. Yes, I tried some time with the switches under the seat. The problem was resolved again.
08.05.2020 20:52 # 7
hanzade34
[QUOTE = dou] good luck, your new vehicle Smile
Thank you when I knew someone told me that when the temperature rises, it gets better when it gets wasted, but I don't know how healthy this comment is. I was very obsessed at first, but later I started to think that these vehicles love the heat :)
08.05.2020 20:52 # 8
dou
In the comments on the internet, I read it that way, but there is a boiling degree of water, after all, there is a question mark in the mind.
08.05.2020 20:52 # 9
talip206
It is normal for the temperature to rise and fall, but it is not normal for it to go up to the stop warning. There are a few possibilities.
1. Thermostat
2. Fan role. (When the fan role is peeled off the bar with the peugeot logo, there is a box inside it. There is a high probability of getting water and oxidation as it is located. You can open it and check it by yourself. I looked at mine and made disaster oxide. These roles send the electricity to the first and second stage of the fan. sometimes it may or may not perform its duty.
3. Circulation. If the temperature rises as the speed increases, the circulation engine is suspected. Bending, breaking, etc. on the wheels of the circulation motor. situations prevent the car from circulating properly. When working at a sufficient amount at low speed, it may not be enough when the speed and speed increase.
08.05.2020 20:52 # 10
M.Ahmet059
good luck your car :)
I changed my 206's press lining in 175 thousand km, it is worth it to change about 300 thousand, it is easy to change the gearbox oil, etc.
08.05.2020 20:52 # 11
hanzade34
[QUOTE = M.Ahmet059] good vehicle :)
I hope my problem is the pressure balata :) by the way, thank you yes, it was 300 thousand.
08.05.2020 20:52 # 12
61AJ669
shaking back and forth can from shaft wedge. Gear 1 knob
If it shakes too much, if it shivers from the clutch, in pull. When he had it done it had improved.
08.05.2020 20:52 # 13
dou
[QUOTE = talip206] [QUOTE = dou] good luck, your new vehicle Smile
1. Thermostat
The next day I bought and changed the thermostat directly
The 1st rank of the fan is running because I worked a little idle until the thermostat turned on
I guess the fan worked in 80 or so, but I did not pay full attention, but it was not 90. The fan stopped slowly when it stopped.
If the fan is working in the second stage, it will be certain that you will change the circulation at least
Ins fanin the second stage is broken, work does not prolong
By the way, would the fan give any warning when the second stage fails?
Because it was 110 degrees from 92 degrees, it did not increase suddenly, directly after 15 seconds, again, 92 did what happened.
08.05.2020 20:52 # 14
boruc
[QUOTE = 61AJ669] can shake back and forth from shaft wedge. Gear 1 knob
What do you call the shaft chock?
Is it a separate piece from the engine or transmission blocks?
08.05.2020 20:52 # 15
cyalman
my guess is the thermostat.
for thrust lining Take off with the handbrake engaged in 1st gear. If the car stops, the thrust lining is intact. If he takes off, he is missing the lining.
08.05.2020 20:52 # 16
hanzade34
What does the shaft wedge do as you say yes, while plugging it up, the trrr sound sounds and vibrates in the 2nd gear.
08.05.2020 20:52 # 17
hanzade34
[QUOTE = cyalman] my guess is the thermostat.
I will try it tomorrow morning, then return to work in the afternoon, I will write here again thanks :)
08.05.2020 20:52 # 18
61AJ669
Sorry I wrote wrong. Of course, the transmission wedge. masters
If he repairs the wedge. Transmission oil, pilastic in the jar,
Workmanship. 150-200. If it does not repair, the workmanship between 200-250 TL, etc.
08.05.2020 20:52 # 19
61AJ669
Sorry, misspelling. Transmission wedge
08.05.2020 20:52 # 20
hanzade34
[QUOTE = 61AJ669] sorry sorry misspelling. Transmission mount [/ QUOTE]
well, can low traction be from this?
Page : / 2
