About the New 2008 Antifreeze Fluid.
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
26.12.2020 19:11 # 1
EvrenosBey
Friends, priorities hello everyone. I just bought the vehicle and joined you directly. As you know, there is no other medium to learn to ask such detail questions. This is what I was wondering; I did not have the fabricated antifreeze liquid in the vehicle measured before receiving the vehicle, but the service gave information as around -30 -35. Later, I was lousy in the industry and I had them measured with Gefo 1100 antifreeze booms in two different shops. I could not understand how the zero antifreeze without the addition of water comes out at this level. I also didn't want to drain the original liquid that was inside. I read that the Gefo 1100 did not measure G13 type antifreeze fluid somewhere, and I guess there is G13 in new vehicles, I was telling him this result. I wanted to ask if anyone can measure it or if it will be -20 in zero vehicles. By the way, I bought the vehicle from Erzurum, so it's a dealer who knows that vehicles will see -30 in this area. I trust the service. Thanks in advance.
29.12.2020 16:11 # 2
GokhaN
Trust the merhabab service, there is no job anyway shops in industry can use different tools to do their job
29.12.2020 23:15 # 3
talip206
They measured mine. They said it shows zero. I came home, filled some of it in a bottle and put it in the freezer at minus 18 degrees. There was no icing the next day. I think don't give credit to things outside. Even use what the factory puts as much as you can.
01.01.2021 18:38 # 4
Diver28
Use your vehicle in good times. Do not poke your vehicle randomly. I don't think it will be a problem.
01.01.2021 20:05 # 5
Kadir
The factory adjusts antifreeze between -35 and -40 degrees. When we bought a new vehicle, I had it measured by the authorized service - it was 40, ours. Yours is probably the new generation vehicle has a red (organic one) antifreeze. If you are not comfortable, have them measure by the authorized service, they have the appropriate bome. By the way, as soon as the factory puts pure antifreeze, pure antifreeze is harmful and the freezing point drops. It puts the antifreeze by mixing it with 50% pure water. After that, if you need a change, you can mix it with half pure water, do not let your antifreeze put in tap water. Our authorized services in Ankara put tap water. For example, take pure water with you and ask the master to add pure water when you change it. It has 9 years or 180.000 km replacement life or it is renewed when the timing set is changed.
02.08.2021 16:36 # 6
EvrenosBey
Thank you to everyone who shared their information and comments, even if it's a little late. I'm sorry for the certain life conditions, I couldn't return, thank you.
