About the JBL 6000.6 amplifier
08.05.2020 18:25 # 1
KIZILASLAN
friends jbl s this is how this amplifier is i am using this amplifier i want to add a second press to my installation would you suggest this amp?
08.05.2020 18:25 # 2
barishrocker
6channel with subwoofer, I couldn't reconcile.
08.05.2020 18:25 # 3
Alicilik
I guess it will be 4 stereo 2 mono?
08.05.2020 18:25 # 4
barishrocker
There is not enough power for the 2nd sub 200rms and just 4ohm on the bridge.
08.05.2020 18:25 # 5
barishrocker
Exactly, if a double sub is to be made, it is a mono condition. According to the subwoofer's size, 1 or 2ohma amplifiers should be looked at ..
With this amplifier, an entry level of 2 mid and a single sub can be fed. Also, 3 or 4 way active system can be installed with processor reinforcement.
08.05.2020 18:25 # 6
KIZILASLAN
I could not get this amp, we couldn't agree on the price, he said 400 TL.
how to use jameson usa 850 amplifier 2500w? 4 channels
08.05.2020 18:25 # 7
Alicilik
If you elaborate a little, let us help you, but we have to know what you want to do.
08.05.2020 18:25 # 8
KIZILASLAN
Let me elaborate on the issue as follows: Pioneer 2550 bt dumbbell tape 1 set Pioneer 6965v2 speaker 1tane Pioneer 309 sub has sub free air pandizota amp as well as Pioneer 6500 f amp, 740 watt amp while cutting the high-headed parts, I cut the amp where I remember the amphitheater, he told me he could reconstruct me. I gave 850 2500 watt amplifier tomorrow we will plug it in and try it ... I had to put a sub in the bag in my mind, but when I understood that all of this would happen :) I searched on the internet I did not get any concrete information about this Jameson 850 amp: Do you know about this amp?
08.05.2020 18:25 # 9
Alicilik
[QUOTE = dehsetilyo] let me elaborate on the subject as follows: Pioneer 2550 bt dumbbell tape 1 set Pioneer 6965v2 speaker 1tane Pioneer 309 sub sub sub air air mounted on the pandizta amp as well as Pioneer 6500 f amplifier, 740 watt amplifier cutting when I play the parts with high bass he said he could get me Jameson gave us the 850 2500 watt amplifier tomorrow we will plug it in and try it ... I had to put a sub in the bag in my mind, but when I understood that all of this wouldn't happen, I gave up on it :) I searched the internet I couldn't get any concrete information about this amp. :? [/ QUOTE]
2550 nice tape o tmm
Not bad at 6965v2. 309sub da tmm
6500f is 760w, it is a little difficult to remove them. I know it gives 60w rms. Even if it is bridged, it cannot exceed 150w rms at 4ohm. If you run full power, it will cut the amp in 5 minutes.
You have to make a slightly stronger stereo or mono + stereo.
It gives us 850 2500w probably 75w. when bridged it becomes 200w. These are the standard sizes. It will revive you a little more.
08.05.2020 18:25 # 10
KIZILASLAN
jameson we'll try 850 tomorrow
Max.Power: 2500 Watt
RMS 4 OHM: 150x4
RMS 2 OHM: 220x4
RMS 4 OHM Mono: 440x2
Fuse: 2x30 A
08.05.2020 18:25 # 11
Alicilik
the vuhuuu
Come outputa is enough for the neighborhood: D jameson gives them maximum power for 30 seconds then becomes coal.
08.05.2020 18:25 # 12
KIZILASLAN
:))))) then we burn that coal in the heater :)))
these exits are going to be obvious in my mind tomorrow white sheep black sheep :)
08.05.2020 18:25 # 13
Alicilik
Its output power is higher than 6500f, it is not a bit exaggerated or rms.
08.05.2020 18:25 # 14
KIZILASLAN
Well, I couldn't get out of the car, we wanted to make a sound system for the car. It was a hard job. For 1 month, I was able to search for anfi sub.
08.05.2020 18:25 # 15
barishrocker
2 different sub would not be nice. Also after pioneer, jamesona is not promoted but I think it is deducted. I think instead of changing the amp, mono amps can be purchased in addition to the stereo amp.
08.05.2020 18:25 # 16
barishrocker
I think the subwoofer is 4ohm single coil 300w rms power .. Xetec 600.1, soundmagus dk600 or jbl 601 or something ..
