About The Gas Pump
28.09.2020 13:49 # 1
foreem
Hello, good forums, I own a 2003 model 1.6v Peugeot 307. My vehicle is currently not working in gasoline. It has done it several times before, but now I can only run it with lpg. I think the problem is with the gas pump. I am a student and when I ask about the change, I get a price of 1-2 thousand TL. Will I repeat my problem in the future if I buy the sub-industry or the exit part of this? What are your suggestions, thank you, good forums. foreem2020-09-28 13:49:37
29.09.2020 21:54 # 2
talip206
What did you do bro, what are they selling for 1 2 thousand. With the gas pump float, you will find a subsidiary industry for 300 to 400 liras. You find it on the Internet. Or ask your peugeot part dealer. In fact, if there is no problem with your float, you can only buy the engine for around 150 lira. So there is no need to change the complete set. You give 50 100 liras of labor. My 206 was also out of order, I just bought the pump and changed it to an electrician.
30.09.2020 09:44 # 3
x571
[QUOTE = talip206] What did you do bro, what are they selling for 1 2 thousand. With the gas pump float, you will find a subsidiary industry for 300 to 400 liras. You find it on the Internet. Or ask your peugeot part dealer. Even if you do not have a problem with your float, you can only buy the engine for around 150 lira. So there is no need to change the complete set. You give 50 100 liras of labor. My 206 was out of order, I just bought the pump and changed it to an electrician.
