About the central lock
08.05.2020 17:14 # 1
206206
& Nbsp; Hello friends
When I lock my car, the left rear door doesn't lock. When I press the door handle by hand, it crashes. when I open it with the remote, all the doors open but & nbsp; the back left door does not lock when i want to lock this can cause this problem, can i solve it myself & nbsp; I would appreciate if anyone knows how to share it
08.05.2020 17:14 # 2
oozcan42
Hello, you can remove the door trim and reach the electric lock mechanism. My advice is to lubricate all the parts with spray oil and give it a try. It is not a very difficult thing to buy and install the lock for that door.
08.05.2020 17:14 # 3
206206
thank you for your advice, removing the door trim & nbsp; is it easy to remove the back door on the window handle & nbsp; & nbsp;
08.05.2020 17:14 # 4
oozcan42
For the door trim, the screw and the glass sketch arm snap ring on the door handle need to be removed. There are plastic buttons that hold the floor up. If you pull them slowly, they will come off. If they are to be broken, the particle has all kinds of them.
08.05.2020 17:14 # 5
Serkan
Check out this thread There is a detailed description of the horse.
08.05.2020 17:14 # 6
206206
thanks guys I'll try tomorrow & nbsp; I hope I can remove the window handle and the rest is easy
