About the 407 temperature problem
08.05.2020 20:57 # 1
serdarr4
I wanted to talk about Peogeot 407 temperature problem and reasons. I hope to shed light on someone on the road one day. In general, there are certain reasons why the vehicle is overheating. As you drive the 407 vehicle, you will have a better understanding of the vehicle. The 407 car is a special car and it is necessary to know its subtleties. For example, 407 cars do not overheat easily. Even if the fan system does not work, there is no obstacle for you to go long. It is stable by experience. 3500km of fans were visited. Only the temperature rises on the slopes and it immediately returns to normal when the slopes are over.
So does peogeot 407 overheat?
If the peogeot 407 vehicle has been discharged on one occasion, if you added water again then it will overheat. It warms up immediately. Because you think the water of the system is complete, but there is air in the system. So how is this secret air taken. There are 2 important points to bleed Peogeot 407 water. One is the air plug on the back of the engine and the other is the thin tube on the thermostat.
Now let's describe how to bleed the peogeot 407 car.
When the engine is at a stop, there is a bleed plug on the heating pipe at the rear of the engine. The size and thread size are the same as the car wheel valve cover. Remove the air plug and start adding water to the water loss. When water comes out of this plug, insert the plug firmly and fill the water container with water. Remember stage 2. he's coming right away.
So far, we have added water to certain parts of the engine, but there is no water in our radiator yet. Remove the clamp located in the middle of the radiator with pliers and add water until the radiator is filled. Replace the radiator tube after the radiator is full. Operate the vehicle on the idler and remove the thermostat from the 2 thin pipes on the water container, that is, the long thin pipe. Add to the water bowl as the water level decreases. When water comes from the thin pipe, it means that the vehicle water is ok. Attach the thin tube to the point on the water container. After adjusting the level in the water container, tightly close the water container door. Your vehicle no longer overheats. If it does, the top cover gasket may be burnt out. I extended the talk a little, but the peogeot 407 vehicle is bled like this. Get well soon. Experience. :) If I tell your story, you will die from laughing.
